Shop the Holiday Gift Guide
Redragon Impact M908 1.8M Braided-Fiber Cable Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
28
Past 30 Days:
128
All Time:
540
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 9 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
As a wired mouse, the braided-fiber cable is integral for overall mouse function. A frayed, worn-down, or malfunctioning cable can cause mouse connectivity to be unstable or even render the mouse unresponsive entirely. This replacement guide will walk you through the steps to replace the Redragon Impact M908's 1.8M braided-fiber cable.
Additionally, we use an iFixit Opening Tool and a metal spudger; however, any flat object with a pointed edge will work. Before beginning, ensure your mouse is unplugged from all devices.
Tools
    1. Redragon Impact M908 1.8M Braided-Fiber Cable Replacement, TEFLON Feet Pads: step 1, image 1 of 3 Redragon Impact M908 1.8M Braided-Fiber Cable Replacement, TEFLON Feet Pads: step 1, image 2 of 3 Redragon Impact M908 1.8M Braided-Fiber Cable Replacement, TEFLON Feet Pads: step 1, image 3 of 3
      • Make sure your mouse is unplugged from all devices.
      • Pick up your mouse and flip it over.
      • Reposition the mouse so that the four feet pads are facing you.
      Ask FixBot
    2. Redragon Impact M908 1.8M Braided-Fiber Cable Replacement: step 2, image 1 of 3 Redragon Impact M908 1.8M Braided-Fiber Cable Replacement: step 2, image 2 of 3 Redragon Impact M908 1.8M Braided-Fiber Cable Replacement: step 2, image 3 of 3
      • Place the pointed edge of a spudger under the corner of one of the feet pads.
      • Press the tool forward, lifting the foot pad until it is fully removed.
      Ask FixBot
    3. Redragon Impact M908 1.8M Braided-Fiber Cable Replacement: step 3, image 1 of 1
      • Repeat the process in step two for the other three feet pads.
      Ask FixBot
    1. Redragon Impact M908 1.8M Braided-Fiber Cable Replacement, 1.8M Braided-Fiber Cable: step 4, image 1 of 3 Redragon Impact M908 1.8M Braided-Fiber Cable Replacement, 1.8M Braided-Fiber Cable: step 4, image 2 of 3 Redragon Impact M908 1.8M Braided-Fiber Cable Replacement, 1.8M Braided-Fiber Cable: step 4, image 3 of 3
      • Unscrew the right 3mm screw using a Phillips #000 screwdriver.
      • Unscrew the remaining four 4mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    2. Redragon Impact M908 1.8M Braided-Fiber Cable Replacement: step 5, image 1 of 2 Redragon Impact M908 1.8M Braided-Fiber Cable Replacement: step 5, image 2 of 2
      • Lift the mouse's top and remove it from the bottom.
      • Place the top to the side, out of the way.
      • The top does not need to be fully removed from the base, and it can be set aside with the connecting cables attached.
      Ask FixBot
    3. Redragon Impact M908 1.8M Braided-Fiber Cable Replacement: step 6, image 1 of 3 Redragon Impact M908 1.8M Braided-Fiber Cable Replacement: step 6, image 2 of 3 Redragon Impact M908 1.8M Braided-Fiber Cable Replacement: step 6, image 3 of 3
      • Unscrew the 3.5mm screw holding the circuit board in place near the scroll wheel using a Phillips #00 screwdriver.
      Ask FixBot
    4. Redragon Impact M908 1.8M Braided-Fiber Cable Replacement: step 7, image 1 of 2 Redragon Impact M908 1.8M Braided-Fiber Cable Replacement: step 7, image 2 of 2
      • Identify the JST-4 pin connector on the circuit board.
      • Place the iFixit opening tool on the lip of the connector.
      • Pull the opening tool up gently, wiggling the tool to remove the connector from the mouse.
      Ask FixBot
Author
with
Alex Johnson
579 Reputation
5 Guides authored
Texas Tech, Team 16-2, Samson Spring 2026 Member of Texas Tech, Team 16-2, Samson Spring 2026
TTU-SAMSON-S26S16G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 128
All Time: 540
