Danger
Potentially Dangerous
Injury may result if this procedure is not followed properly. Use caution and follow all warnings.
Danger
Introduction
AA (and AAA) batteries power EVERYTHING. Portable radios, portable game systems, flashlights, remotes, toys, toys ( ͡° ͜ʖ ͡°), and, well, practically everything! However, these guys never last, and while cheap, the price stacks up over time. Yes, you can go with rechargables, but they literally cost AT LEAST 3 times as much. What if I told you that you can turn any battery into a rechargeable for free? Crazy, right? Well, actually, not so much.
Tools
Parts
  1. Can be any combination of AAA or AA batteries. You need at least 2.
    • Can be any combination of AAA or AA batteries. You need at least 2.
    • Make sure they have as little charge as possible to avoid leakage.
    • Any type of dry AA/AAA battery will work, such as NiMH, NiZN, MiCD, etc.
  2. They may leak if they are not completely dead, but you can just scratch the residue away with your finger or a flathead.
    • They may leak if they are not completely dead, but you can just scratch the residue away with your finger or a flathead.
    • They won't explode. and only get slightly warm, but you might want to charge them in a safe space.
    • Plug it into the wall. the LED should come on. Wait until the LED changes or goes off.
    • It should take 8-12 hours (on a cheap charger. Don't risk your expensive one). This is normal, as this is how long normal rechargables take.
    • These guys won't last as long as normal rechargables, but they cost way less!
Some of the battery's "fuel" may leak out. You just need to scrape it off the charger. Remember, only use dead batteries, and while it won't explode or catch fire, it's best to be safe and not charge it over carpet or flammables.
8 other people completed this guide.
MaxAwesomeness GB (Max)
381 Reputation
1 Guide authored
One Comment
Recharging alkaline batteries is not recommended. They can be recharged to a limited extent but if you’re going to do so then it you will get best results with a top-up charge while they are still reasonably fresh. Some years ago one or two manufacturers marketed ranges of rechargeable alkaline cells but performance was very poor compared with NiCd or NiMH and you had to use a special charger with a completely different voltage/current charging profile to a standard charger, hence they never caught on. Yes, proper rechargeable batteries are more expensive, but heck, you can recharge them hundreds of times so over their life they will be 50 or 100 times cheaper! Why risk damage to your precious electronic equipment from leaking batteries that you forgot to remove?
Philip Le Riche - Reply
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 87
All Time: 957
