Rear Case Separation
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Rear Case Separation, Unclip the right end of the middle trim: step 1, image 1 of 2 Rear Case Separation, Unclip the right end of the middle trim: step 1, image 2 of 2
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. Rear Case Separation, Unclip the lower-right edge of the middle trim: step 2, image 1 of 3 Rear Case Separation, Unclip the lower-right edge of the middle trim: step 2, image 2 of 3 Rear Case Separation, Unclip the lower-right edge of the middle trim: step 2, image 3 of 3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. Rear Case Separation, Unclip the left end of the middle trim: step 3, image 1 of 2 Rear Case Separation, Unclip the left end of the middle trim: step 3, image 2 of 2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. Rear Case Separation, Unclip the lower-left edge of the middle trim: step 4, image 1 of 3 Rear Case Separation, Unclip the lower-left edge of the middle trim: step 4, image 2 of 3 Rear Case Separation, Unclip the lower-left edge of the middle trim: step 4, image 3 of 3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. Rear Case Separation, Remove the middle trim: step 5, image 1 of 3 Rear Case Separation, Remove the middle trim: step 5, image 2 of 3 Rear Case Separation, Remove the middle trim: step 5, image 3 of 3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
  6. Rear Case Separation, Remove the L1 button: step 6, image 1 of 3 Rear Case Separation, Remove the L1 button: step 6, image 2 of 3 Rear Case Separation, Remove the L1 button: step 6, image 3 of 3
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
  7. Rear Case Separation, Remove the R1 button: step 7, image 1 of 3 Rear Case Separation, Remove the R1 button: step 7, image 2 of 3 Rear Case Separation, Remove the R1 button: step 7, image 3 of 3
    • Repeat the previous step to remove the R1 button.
  8. Rear Case Separation, Remove the rear case screws: step 8, image 1 of 2 Rear Case Separation, Remove the rear case screws: step 8, image 2 of 2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
  9. Rear Case Separation: step 9, image 1 of 2 Rear Case Separation: step 9, image 2 of 2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
  10. Rear Case Separation, Separate the rear case: step 10, image 1 of 3 Rear Case Separation, Separate the rear case: step 10, image 2 of 3 Rear Case Separation, Separate the rear case: step 10, image 3 of 3
    • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
    • Use the point of a spudger to release the two clips on either side of the headset jack.
  11. Rear Case Separation: step 11, image 1 of 3 Rear Case Separation: step 11, image 2 of 3 Rear Case Separation: step 11, image 3 of 3
    • Tight plastic clips secure the left and right edges of the rear case.
    • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
    • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
  12. Rear Case Separation: step 12, image 1 of 3 Rear Case Separation: step 12, image 2 of 3 Rear Case Separation: step 12, image 3 of 3
    • Repeat the previous step on the right edge to release its clips.
  13. Rear Case Separation: step 13, image 1 of 2 Rear Case Separation: step 13, image 2 of 2
    • Lay your controller upside down so the joysticks are on your work surface.
    • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
Sam Omiotek
88,046 Reputation
290 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 24
All Time: 157
