Introduction
This guide will help you replace the top outer casing of the mouse that holds some of the electronics for the LED lighting. Be sure to use caution when unplugging the wires, for this could result in the mouse not working properly. Also use caution when removing the plastic shell, it is fragile and it could be cracked upon removal.
Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
Gently remove the top plastic plate of the mouse.
Unplug the white cord from the circuit board.
