Introduction
This guide will help you replace the motherboard, which allows your mouse to function. Be sure to keep track of the 5mm screws and the 7mm screws.
Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
Using a Phillips #00 screwdriver, remove the 5mm screw holding the scroll wheel in place.
Using a Phillips #00 screwdriver, remove all five 5mm screws that connect the motherboard to the main frame.
4 Comments
Surprised this is rated Difficult. :f
Do you know where I can find the motherboard for the mouse?
Where can I get a replacement motherboard?
I followed these steps for the razer naga hex and it's the same. Just a tip for people that want to take off the teflon tapes, you don't need to take off the big one to the side, the only 4 screws holding the case to the top part of the mouse are under the 4 small teflon tapes in each corner. Good luck!
