Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
Gently pull up on the right plate on the mouse; separating it.
Carefully repeat this step for the left side.
Thank you for this guide! I was able to get my mouse from 2014 open and clean it out
Take your nylon spudger to gently pry the battery pack from the device.
Remove the foam on the battery shell for your new battery.
Unplug the power cord from the circuit board in the mouse.
Reposting from below: https://www.amazon.com/gp/product/B0767K... - for this battery you’ll need to switch the battery leads to match the polarity.
Also, you should remove the tape, or provide your own for the replacement battery.
Under the battery, remove the two screws holding the battery mount in place.
Remove the battery mount.
2 Comments
Did you find the strip? Im looking or it as well.
