Introduction
The Razer DeathAdder Chroma may experience critical issues related to the device not being registered by the computer via a fault in the USB cable.
Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
Turn the mouse over so the bottom is facing down.
Separate the top casing from the bottom base by pulling the top casing upwards.
Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
