Razer Blade 15" (2018) Charging Port Disconnection
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Razer Blade 15" (2018) Charging Port Disconnection, Prepare your laptop for disassembly: step 1, image 1 of 2 Razer Blade 15" (2018) Charging Port Disconnection, Prepare your laptop for disassembly: step 1, image 2 of 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15" (2018) Charging Port Disconnection, Unfasten the back cover: step 2, image 1 of 1
    • Rotate your laptop so the screen hinge is farthest from you.
    • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
  3. Razer Blade 15" (2018) Charging Port Disconnection, Insert an opening pick: step 3, image 1 of 3 Razer Blade 15" (2018) Charging Port Disconnection, Insert an opening pick: step 3, image 2 of 3 Razer Blade 15" (2018) Charging Port Disconnection, Insert an opening pick: step 3, image 3 of 3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
    • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15" (2018) Charging Port Disconnection, Angle the opening pick: step 4, image 1 of 3 Razer Blade 15" (2018) Charging Port Disconnection, Angle the opening pick: step 4, image 2 of 3 Razer Blade 15" (2018) Charging Port Disconnection, Angle the opening pick: step 4, image 3 of 3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
    • Insert your pick up to 10 mm (0.4 in) deep.
  5. Razer Blade 15" (2018) Charging Port Disconnection, Free the bottom right corner: step 5, image 1 of 3 Razer Blade 15" (2018) Charging Port Disconnection, Free the bottom right corner: step 5, image 2 of 3 Razer Blade 15" (2018) Charging Port Disconnection, Free the bottom right corner: step 5, image 3 of 3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15" (2018) Charging Port Disconnection, Free the front edge: step 6, image 1 of 3 Razer Blade 15" (2018) Charging Port Disconnection, Free the front edge: step 6, image 2 of 3 Razer Blade 15" (2018) Charging Port Disconnection, Free the front edge: step 6, image 3 of 3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
  7. Razer Blade 15" (2018) Charging Port Disconnection, Remove the back cover: step 7, image 1 of 3 Razer Blade 15" (2018) Charging Port Disconnection, Remove the back cover: step 7, image 2 of 3 Razer Blade 15" (2018) Charging Port Disconnection, Remove the back cover: step 7, image 3 of 3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
  8. Razer Blade 15" (2018) Charging Port Disconnection, Soften the battery cable tape adhesive: step 8, image 1 of 2 Razer Blade 15" (2018) Charging Port Disconnection, Soften the battery cable tape adhesive: step 8, image 2 of 2
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or create a fire hazard.
  9. Razer Blade 15" (2018) Charging Port Disconnection, Peel up the battery cable tape: step 9, image 1 of 3 Razer Blade 15" (2018) Charging Port Disconnection, Peel up the battery cable tape: step 9, image 2 of 3 Razer Blade 15" (2018) Charging Port Disconnection, Peel up the battery cable tape: step 9, image 3 of 3
    Tool used on this step:
    Buy
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
  10. Razer Blade 15" (2018) Charging Port Disconnection, Disconnect the battery: step 10, image 1 of 3 Razer Blade 15" (2018) Charging Port Disconnection, Disconnect the battery: step 10, image 2 of 3 Razer Blade 15" (2018) Charging Port Disconnection, Disconnect the battery: step 10, image 3 of 3
    • Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
  11. Razer Blade 15" (2018) Charging Port Disconnection, Label the antenna cables: step 11, image 1 of 3 Razer Blade 15" (2018) Charging Port Disconnection, Label the antenna cables: step 11, image 2 of 3 Razer Blade 15" (2018) Charging Port Disconnection, Label the antenna cables: step 11, image 3 of 3
    • In the next steps, you'll disconnect and move the Wi-Fi cables to access other components.
    • The antenna cables look very similar. Label one of them with a piece of tape or marker. Do the same to its socket on the Wi-Fi card.
  12. Razer Blade 15" (2018) Charging Port Disconnection, Disconnect the Wi-Fi card: step 12, image 1 of 3 Razer Blade 15" (2018) Charging Port Disconnection, Disconnect the Wi-Fi card: step 12, image 2 of 3 Razer Blade 15" (2018) Charging Port Disconnection, Disconnect the Wi-Fi card: step 12, image 3 of 3
    $3.99
    Buy
    • Insert one arm of angled tweezers under the metal neck of each antenna cable and pry up to disconnect it.
  13. Razer Blade 15" (2018) Charging Port Disconnection, Move the antenna cables: step 13, image 1 of 2 Razer Blade 15" (2018) Charging Port Disconnection, Move the antenna cables: step 13, image 2 of 2
    • Use tweezers or your fingers to move the antenna cables to the left, away from the charging connector.
  14. Razer Blade 15" (2018) Charging Port Disconnection, Disconnect the charging port: step 14, image 1 of 3 Razer Blade 15" (2018) Charging Port Disconnection, Disconnect the charging port: step 14, image 2 of 3 Razer Blade 15" (2018) Charging Port Disconnection, Disconnect the charging port: step 14, image 3 of 3
    • Use your spudger to push on alternating sides of the charging port connector to "walk" it out of its socket.
Clay Eickemeyer
86,091 Reputation
455 Guides authored
Guide Team Member of Guide Team
Staff
9 Members
13,297 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 43
