Introduction
Following a domestic accident, a drink that was spilled on the controller, it no longer works normally. Two keys no longer work (right arrow and L2). The failure comes from a tablecloth which has lost its conductive element (see photo). We are going to replace this tablecloth.
Here is the controller to troubleshoot.
The controller is made of 2 large plastic parts. To detach them, press the lever as shown in the photo. A gap should form, allowing you to insert an item (like the iFixit Opening Picks).
Open the controller, taking care not to detach the R2 and L2 triggers. Otherwise, be careful not to lose the springs of these triggers.
Déconnecter la batterie en tirant légèrement sur le connecteur blanc relié à la face avant de la manette.
Déconnecter le fil électrique qui relie les 2 partie de la manette entre-elles en prenant soin de ne tirer que sur la languette au bout.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
