Quigg MD 17560 Vacuum Cleaner Battery Replacement
  1. Quigg MD 17560 Vacuum Cleaner Battery Replacement, Opening the vacuum cleaner: step 1, image 1 of 3 Quigg MD 17560 Vacuum Cleaner Battery Replacement, Opening the vacuum cleaner: step 1, image 2 of 3 Quigg MD 17560 Vacuum Cleaner Battery Replacement, Opening the vacuum cleaner: step 1, image 3 of 3
    • Photo 1: with a cutter, cut the label along the dividing line of the two sides of the case.
    • Photo 2: Using a No. 2 Phillips screwdriver, remove the six screws. (red arrows)
    • Photo 3: Seperate the two halves.
  2. Quigg MD 17560 Vacuum Cleaner Battery Replacement, Cleaning the case.: step 2, image 1 of 3 Quigg MD 17560 Vacuum Cleaner Battery Replacement, Cleaning the case.: step 2, image 2 of 3 Quigg MD 17560 Vacuum Cleaner Battery Replacement, Cleaning the case.: step 2, image 3 of 3
    • Photo 1: Remove the motor housing, the small PCB with the charging connector and the battery. Also remove the electronic parts of the on/off switch from the case.
    • Photo 2: The two parts of the case and the small blue and transparent plastic parts can be cleaned using dish washing liquid.
    • Photo 3: Remove the black plastic cover from the impeller by pulling on it to clean the impeller with air and/or a brush.
  3. Quigg MD 17560 Vacuum Cleaner Battery Replacement: step 3, image 1 of 1
    • Photo 7: The battery is a 'pack' made up of two 18650 3.7 V. batteries with a balancing wire (the yellow wire connected to the motor's PCB).
To reassemble your device, follow the instructions in reverse order.
3 other people completed this guide.
Special thanks to these translators:
fr en
100%
Juan Garcia is helping us fix the world! Want to contribute?
Start translating ›
Madcat
1,232 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 43
All Time: 364
