Fix Your Stuff
Right to Repair
Store
Tools
Parts
  1. Start with removing the three screws to open the case. After removing the screws pull/push the case to the backside to remove it.
    • Start with removing the three screws to open the case. After removing the screws pull/push the case to the backside to remove it.
  2. Now you can remove the power supply unit. This requires 5 more screws on the back and two inside the case to be removed. Now you can remove the power supply unit. This requires 5 more screws on the back and two inside the case to be removed.
    • Now you can remove the power supply unit. This requires 5 more screws on the back and two inside the case to be removed.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Remove the remaining two screws on the back side. Two more can be found on the bottom and one on the bottom corner left and right. Noch you can careful remove the back of the UX-500P. Remove the remaining two screws on the back side. Two more can be found on the bottom and one on the bottom corner left and right. Noch you can careful remove the back of the UX-500P. Remove the remaining two screws on the back side. Two more can be found on the bottom and one on the bottom corner left and right. Noch you can careful remove the back of the UX-500P.
    • Remove the remaining two screws on the back side. Two more can be found on the bottom and one on the bottom corner left and right. Noch you can careful remove the back of the UX-500P.
  5. Now you can remove the final four screws that attaches the 120mm fan to the back of the UX500-P. Now you can remove the final four screws that attaches the 120mm fan to the back of the UX500-P.
    • Now you can remove the final four screws that attaches the 120mm fan to the back of the UX500-P.
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
Chris Klinger
33 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 124
