Prusa MK4 Print Fan Replacement
  1. Prusa MK4 Print Fan Replacement, Print Fan: step 1, image 1 of 3 Prusa MK4 Print Fan Replacement, Print Fan: step 1, image 2 of 3 Prusa MK4 Print Fan Replacement, Print Fan: step 1, image 3 of 3
    • Make sure the printer is turned off and the power cord is unplugged before you begin.
    • Move the extruder to the middle of the X and Y axes to ensure the workspace is clear.
    • Remove the Loveboard cover from the toolhead and set it aside.
    Ask FixBot
  2. Prusa MK4 Print Fan Replacement: step 2, image 1 of 2 Prusa MK4 Print Fan Replacement: step 2, image 2 of 2
    • Use tweezers to gently grip and disconnect the plastic body of the cooling fan connector from the Loveboard.
    • You can use your fingers as well; tweezers are just easier to use.
    • Pull only on the plastic connector body. Pulling directly on the wires can damage them or rip them out of the delicate crimp connector.
    Ask FixBot
  3. Prusa MK4 Print Fan Replacement: step 3, image 1 of 2 Prusa MK4 Print Fan Replacement: step 3, image 2 of 2
    • Use a 2.4mm hex key to unscrew the fasteners holding the print fan to the side of the extruder.
    Ask FixBot
  4. Prusa MK4 Print Fan Replacement: step 4, image 1 of 3 Prusa MK4 Print Fan Replacement: step 4, image 2 of 3 Prusa MK4 Print Fan Replacement: step 4, image 3 of 3
    • Pull the damaged fan free from the extruder body, and if needed make sure you clean the plastic waste on the shroud!
    Ask FixBot
  5. Prusa MK4 Print Fan Replacement: step 5, image 1 of 2 Prusa MK4 Print Fan Replacement: step 5, image 2 of 2
    • Route the replacement fan's cable neatly through the dedicated channel in the print fan holder.
    • The cable must not protrude out, otherwise the cooling fan will not be held into the holder properly.
    • Hold the new fan in place against the extruder body.
    Ask FixBot
  6. Prusa MK4 Print Fan Replacement: step 6, image 1 of 3 Prusa MK4 Print Fan Replacement: step 6, image 2 of 3 Prusa MK4 Print Fan Replacement: step 6, image 3 of 3
    • Using a 2.3mm hex insert and tighten the two long 2.5mm screws to secure the fan. Hold the fan tightly, if needed, to make sure there is no gap between the cooling fan and the shroud.
    • Tighten the screws gently to avoid cracking the plastic fan casing.
    • Verify that the screw ends are visible on the opposite side of the shroud to ensure the fan is secured with no gaps.
    Ask FixBot
  7. Prusa MK4 Print Fan Replacement: step 7, image 1 of 3 Prusa MK4 Print Fan Replacement: step 7, image 2 of 3 Prusa MK4 Print Fan Replacement: step 7, image 3 of 3
    • Gently snap the new cooling fan's connector into its dedicated port on the Loveboard.
    Ask FixBot
  8. Prusa MK4 Print Fan Replacement: step 8, image 1 of 1
    • Place the Loveboard cover back on.
    Ask FixBot
Once assembled, plug in the printer, turn it on and navigate to Control > Temperature > Print fan on the LCD screen to verify the new fan spins correctly.
Simranjit
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 60
