Turn off the computer.
Take the slide unlocked into position, remove the battery.
Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
Using the Phillips # 1 screwdriver, unscrew the 3 mounting screws of the processor heat sink.
Note position of marker triangle as this will determine the positioning of the processor during replacement.
Unlock the coupling system of the processor with a classic screwdriver.
Make sure that you do not remove the heat-dissipating paste between the processor and the heat sink, as this is the only way to ensure that the processor is properly cooled.
For reassembly, follow the instructions in the reverse order
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
