Propel Gyro-X Stabilizer Replacement
  1. Propel Gyro-X Stabilizer Replacement, Top Propellor Blades: step 1, image 1 of 1
    • Stabilizing links are easy to break. Be gentle when prying them off.
    • Place the tweezers on the sides of the links and pull straight away from the top point of connection.
  2. Propel Gyro-X Stabilizer Replacement: step 2, image 1 of 2 Propel Gyro-X Stabilizer Replacement: step 2, image 2 of 2
    • Remove the two 6.0 mm Phillips #00 screws from the rotors.
  3. Propel Gyro-X Stabilizer Replacement: step 3, image 1 of 2 Propel Gyro-X Stabilizer Replacement: step 3, image 2 of 2
    • Pull the rotors away from the mounting brackets.
  4. Propel Gyro-X Stabilizer Replacement, Stabilizer: step 4, image 1 of 1
    • Remove the two 5mm PHillips #00 screws screws
  5. Propel Gyro-X Stabilizer Replacement: step 5, image 1 of 2 Propel Gyro-X Stabilizer Replacement: step 5, image 2 of 2
    • Using the tweezers twist the rotor attachment bracket apart.
  6. Propel Gyro-X Stabilizer Replacement: step 6, image 1 of 1
    • Remove the two 6mm #00 screws
  7. Propel Gyro-X Stabilizer Replacement: step 7, image 1 of 1
    • Pull up on the stabilizer assembly to remove it completely from the drive shaft.
Sarah Atmadja
404 Reputation
3 Guides authored
Cal Poly, Team 17-2, Forte Spring 2015 Member of Cal Poly, Team 17-2, Forte Spring 2015
CPSU-FORTE-S15S17G2
4 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 2,488
