Introduction
Sometimes through typical wear and tear, your grill may not want to start right. If you live in an area where you don't use it year round after a period of time, it doesn't want to start correctly, It could be numerous things. This guide shows the most common isuses that could prevent a grill front starting or running properly, from the battery in the igniter to the propane hose and regulator.
Completely close the propane tank by turning the valve on the top clockwise. This prevents propane from leaking during the replacement.
Turn the knob on the hose counter clockwise to disconnect it from the tank.
3 other people completed this guide.
2 Comments
I have a Napoleon travel series P285Q X. Do I need to purchase a control valve with a hose to convert from a 1 - 20 lb tank?
Question. Do I need to purchase a pressure valve and a hose to convert from a 1 lb to a 20 lb tank. The bbq is a Napoleon 285 pro series travel.
