Tools
Parts
  1. Pull the foot support out of the support leg.
    • Pull the foot support out of the support leg.
  2. Use a thin rod (eg a cable tube) to push through the support from the foot side and gently push the spring downwards.
    • Use a thin rod (eg a cable tube) to push through the support from the foot side and gently push the spring downwards.
    • Pull the spring out of the support leg at the bottom.
    • Insert the spring with the curved side forward from the foot side into the support leg.
    • The spring bolt must point to the same side as the hole in the bottom of the foot bar.
    • Push the spring all the way into the foot.
    • Then put in the rod again and carefully push the spring downwards.
    • When the spring appears in the hole, continue to push gently until the bolt pops into the hole.
    • Now push the foot support back into the support leg.
Congratulations, you did it.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Markus Mauchle
1 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 67
