Pull the foot support out of the support leg.
Use a thin rod (eg a cable tube) to push through the support from the foot side and gently push the spring downwards.
Pull the spring out of the support leg at the bottom.
Insert the spring with the curved side forward from the foot side into the support leg.
The spring bolt must point to the same side as the hole in the bottom of the foot bar.
Push the spring all the way into the foot.
Then put in the rod again and carefully push the spring downwards.
When the spring appears in the hole, continue to push gently until the bolt pops into the hole.
Congratulations, you did it.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
