Introduction
So, here it is, Sunday evening and my daughter attempts to make popcorn that we all get to enjoy while watching a movie. Gets the kernels, puts them into the popper, plugs it in and.....nothing. Daddy can you 'fixit'? Will see what we find....
This is the Hot Air Popper. worked pretty good and has lots of 'miles' on it. We used it often, and it did work well. New one would be about $20 at some major department stores.
But hey, I am frugal....
The bottom cover is fastened with four screws. Remove those.
Once the bottom cover is removed, the blower motor is clearly visible.
Where the power cable attaches to the motor, are four diodes. These diodes only allow half-cycle of a full cycle of positive and negative power cycle to reach the motor.
The motor only gets current in one direction,allowing it to spin in one direction. After all, we are dealing with AC current here.
The problem that was visible on close inspections with a magnifying glass, was a charred diode.
removed the diode (it was attached by point-to-point soldering to the other ones) by de-soldering.
Replace the faulty diode. Description on the diode was V81 N4001.
6 other people completed this guide.
