PowerBook G4 Titanium DVI DC-In Board Replacement
  1. PowerBook G4 Titanium DVI DC-In Board Replacement, Battery: step 1, image 1 of 2 PowerBook G4 Titanium DVI DC-In Board Replacement, Battery: step 1, image 2 of 2
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
  2. PowerBook G4 Titanium DVI DC-In Board Replacement, Lower Case: step 2, image 1 of 2 PowerBook G4 Titanium DVI DC-In Board Replacement, Lower Case: step 2, image 2 of 2
    • Remove the seven T8 Torx screws from the lower case.
    • Using your thumbs, slide the lower case toward the front of the computer.
    • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  3. PowerBook G4 Titanium DVI DC-In Board Replacement, DC-In Board: step 3, image 1 of 1
    • Disconnect the large DC-In connector from the right side of the logic board.
  4. PowerBook G4 Titanium DVI DC-In Board Replacement: step 4, image 1 of 1
    • Remove the two T6 Torx screws from the DC-In board.
  5. PowerBook G4 Titanium DVI DC-In Board Replacement: step 5, image 1 of 1
    • Lift the DC-In board out of the computer by pulling up and away from you.
    • If you don't have a 667 MHz computer, there is a fan in this location which makes it a bit difficult to remove the DC-In board.
    • If there is a fan present, rotate the DC-In board slightly clockwise before easing it out at a slight angle in order to clear the fan clamp on top of it.
Attached Documents
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 12
All Time: 15,384
