Installing PowerBook G4 Aluminum 12" 867 MHz Keyboard
  1. Installing PowerBook G4 Aluminum 12" 867 MHz Keyboard, Battery: step 1, image 1 of 1
    • Use a coin to turn the battery locking screw 90 degrees to the right.
    • Lift the battery out of the computer.
  2. Installing PowerBook G4 Aluminum 12" 867 MHz Keyboard, EMI Finger: step 2, image 1 of 1
    • Remove the four Phillips screws from the memory door.
    • Slide the memory door away from the memory compartment.
  3. Installing PowerBook G4 Aluminum 12" 867 MHz Keyboard: step 3, image 1 of 1
    • Remove the long black Phillips screw next to the memory card.
    • Remove the small EMI finger beneath the black screw.
  4. Installing PowerBook G4 Aluminum 12" 867 MHz Keyboard, Keyboard: step 4, image 1 of 1
    • On the keyboard, remove the F1, F2, F11, and F12 keys.
    • This is scary - take a deep breath before continuing. Place your index finger under the upper left corner of the key and lift up until you hear a click. Then, transfer your finger to the left edge of the key and lift up to pull the key off.
    • You're freeing the two tabs on the left of the key from the two small holes in the plastic scissors mechanism.
    • When replacing the keys in the keyboard, place the key directly over the slot where it will go and press down until you hear the key click into place.
  5. Installing PowerBook G4 Aluminum 12" 867 MHz Keyboard: step 5, image 1 of 1
    • Use your fingernail or a small flathead screwdriver to peel up the gray stickers covering each of the screws.
  6. Installing PowerBook G4 Aluminum 12" 867 MHz Keyboard: step 6, image 1 of 1
    • Remove the two short Phillips screws.
  7. Installing PowerBook G4 Aluminum 12" 867 MHz Keyboard: step 7, image 1 of 1
    • Lift the keyboard by the 'esc' and 'eject' keys and gently lift up until the keyboard is vertical.
  8. Installing PowerBook G4 Aluminum 12" 867 MHz Keyboard: step 8, image 1 of 1
    • Grasp the keyboard connector ribbon near the connector and disconnect it from the logic board.
Attached Documents
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 14,829
