PowerBook G3 Wallstreet Display Replacement
  1. PowerBook G3 Wallstreet Display Replacement, Keyboard: step 1, image 1 of 1
    • Remove both expansion bay modules using the levers on the front of the computer.
    • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
    • Pull the tabs toward yourself and the keyboard will pop up.
  2. PowerBook G3 Wallstreet Display Replacement: step 2, image 1 of 1
    • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
    • Rest the keyboard on the trackpad.
    • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
  3. PowerBook G3 Wallstreet Display Replacement: step 4, image 1 of 1
    • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
  4. PowerBook G3 Wallstreet Display Replacement: step 5, image 1 of 1
    • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
    • Once the strain relief cables are free, lift the keyboard off.
  5. PowerBook G3 Wallstreet Display Replacement: step 6, image 1 of 1
    • Your laptop should look approximately like this.
  6. PowerBook G3 Wallstreet Display Replacement, Heat Shield: step 7, image 1 of 1
    • Remove the two Phillips screws from the heat shield.
    • One screw is shorter than the other. When putting the Wallstreet back together, this screw goes in the middle of the heat shield.
  7. PowerBook G3 Wallstreet Display Replacement: step 8, image 1 of 1
    • Grasp the metal handle on the heat shield and pull up and toward yourself.
  8. PowerBook G3 Wallstreet Display Replacement, Hard Drive: step 9, image 1 of 1
    • Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
  9. PowerBook G3 Wallstreet Display Replacement: step 10, image 1 of 1
    • Grasp the hard drive bracket on the left side and pull up and to the left.
  10. PowerBook G3 Wallstreet Display Replacement: step 11, image 1 of 1
  11. PowerBook G3 Wallstreet Display Replacement, Processor: step 12, image 1 of 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
    • Remove the processor by sliding it up and to the right.
    • The processor and RAM can be removed as a unit. It is not necessary to remove the RAM from the processor.
    • There are two tabs on the left side of the processor that fit into slots on the metal framework. Make sure these tabs are in the slots.
  12. PowerBook G3 Wallstreet Display Replacement, Modem: step 13, image 1 of 1
    • Remove the single Phillips screw from the modem.
    • Disconnect the orange PMU cable by pulling it directly up.
  13. PowerBook G3 Wallstreet Display Replacement: step 14, image 1 of 1
    • Disconnect the modem from the logic board by lifting up on the right side using a spudger, the tip of your finger, or a flat non-metal tool.
    • Remove the modem by sliding it up and to the right.
  14. PowerBook G3 Wallstreet Display Replacement: step 15, image 1 of 1
  15. PowerBook G3 Wallstreet Display Replacement, Clutch Cover: step 16, image 1 of 1
    • Push the display back so that it lies flat.
    • Slip a spudger or your index finger under the clutch cover near the power button and pull upward until you feel it come free.
    • Repeat the previous step on the left side.
  16. PowerBook G3 Wallstreet Display Replacement: step 17, image 1 of 1
    • Lift the clutch cover off by rotating it up and then toward you.
  17. PowerBook G3 Wallstreet Display Replacement, Display: step 18, image 1 of 1
    • Disconnect the orange display data cable on the left side of the computer. Grasp the cable near the connector and pull directly up.
  18. PowerBook G3 Wallstreet Display Replacement: step 19, image 1 of 1
    • Disconnect the orange display inverter cable on the right side of the computer. Grasp the cable near the connector and pull directly up.
    • Make sure that both cables are free from the plastic casing before proceeding to the next step.
  19. PowerBook G3 Wallstreet Display Replacement: step 20, image 1 of 1
    • Turn the laptop around so that its back faces you.
    • Open the port door located at the back of the laptop.
    • Remove the four black T8 Torx screws.
  20. PowerBook G3 Wallstreet Display Replacement: step 21, image 1 of 1
    • Turn the laptop back around so that the screen faces you.
    • Adjust the display so that it is in a vertical position.
    • Hold the display on both sides and pull directly up until its hinges are free of their mounts
  21. PowerBook G3 Wallstreet Display Replacement: step 22, image 1 of 1
    • Your laptop should look like this.
Attached Documents
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 9,188
