Heat the right side gently at 140 F for about 3 minutes.
Do not over heat or it will melt the housing.
After heating, gently remove the cover/casing as shown in the picture.
Take your time and re-heat if cover/casing does not remove smoothly.
Desolder battery using soldering iron and replace with replacement battery.
After battery is replaced, apply super glue to the border of the inside of the battery cover/casing and put it back in place.
Use small clamps/binder clip to hold the housing in place while the super glue dries up.
