Introduction
Use this guide to replace the film door (aka film processing unit, or FPU) in your Polaroid Flip instant camera.
The film door is made up of the print roller secured in its plastic housing. The print roller is responsible for evenly spreading the development chemicals across your instant film photos. If your photos look uneven or have lines, you might need to replace the film door.
Before replacing the film door, try cleaning the rollers and see if it fixes your problem. It's possible dust and dirt buildup on the rollers is causing uneven photos.
If you have any film left, take some photos! Then remove the cartridge. Disassembly will expose any leftover film.
Unplug all cables from your camera.
Fully close the flash unit at the front of the camera to turn it off.
Hold down the latch on the left side of the camera and open the film door.
Tool used on this step:Magnetic Project Mat$19.95
Use a Phillips screwdriver to remove the 5.9 mm‑long screw securing the rear shell.
Slide the bottom shell towards the back of the camera to release the clips securing it.
Lift and remove the shell.
Place the shell onto the frame so it hangs over the back about about half an inch (~13 mm), creating a gap near the center of the camera. This allows room for the clips to slide into place.
Push down on the shell and slide it towards the front of the camera to engage the clips—you should feel them slide into place.
Use a Phillips screwdriver to remove the two 3 mm‑long film door hinge screws (one on either side of the camera).
Use the flat end of a spudger to push one of the film door hinges away from the camera and off its post.
Repeat the process to detach the other hinge.
Check to see if either of the small, plastic hinge grommets stayed on their posts. If they did, remove them and set them aside.
Remove the film door.
Make sure there are grommets installed in the film door hinges. To install them, press the grommets into the film door hinges, with the wide end facing in.
Hook one of the hinges on its post and then push the other one into place until it snaps over its post.
