Polaroid Automatic 100 Bottom Frame Spring Replacement
  1. Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: step 1, image 1 of 3 Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: step 1, image 2 of 3 Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: step 1, image 3 of 3
    • Fully extend the bellows to prevent collapse using the #1 tab.
    • Remove the camera cover in order to make the camera easier to work with.
    • When collapsing bellows, press down on the metal frame above the bellows.
  2. Polaroid Automatic 100 Bottom Frame Spring Replacement: step 2, image 1 of 1
    • Remove the Phillips #0 6mm screw on the shutter mount and the washers using a size 5 nut driver.
  3. Polaroid Automatic 100 Bottom Frame Spring Replacement: step 3, image 1 of 1
    • Unscrew the 4.5 mm Phillips screw on the right with a Phillips #0 Screwdriver.
  4. Polaroid Automatic 100 Bottom Frame Spring Replacement: step 4, image 1 of 3 Polaroid Automatic 100 Bottom Frame Spring Replacement: step 4, image 2 of 3 Polaroid Automatic 100 Bottom Frame Spring Replacement: step 4, image 3 of 3
    • Remove the spring from the shutter mount.
    • The hooks on the ends of the spring within the shutter mount may recoil when being removed, and may be sharp enough to puncture skin.
    • When reassembling, getting the smaller screw on the right hand side can be challenging. It may be helpful to tip the camera upside down so that gravity helps the screw fall into place.
2 other people completed this guide.
Katie Miller
680 Reputation
5 Guides authored
Cal Poly, Team 4-3, Maness Spring 2015 Member of Cal Poly, Team 4-3, Maness Spring 2015
CPSU-MANESS-S15S4G3
4 Members
6 Guides authored
One Comment
Thank you so very much!!!
You saved my camera and my sanity!!!!
CAROL HOLDER - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 1,074
