Shop the Holiday Gift Guide
Pokémon™ GO Plus+ Battery Replacement
Views: 25K
View statistics:
Past 24 Hours:
35
Past 7 Days:
233
Past 30 Days:
1,236
All Time:
25,110
Comments: 13
3 comments on steps, 10 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
The Pokemon Go Plus+ uses the same battery replacement as the Nintendo Switch Official Joy-Cons, so finding the battery should be very easy!
Parts
Tools
  • Spudger
    4.9
    1. Pokémon™ GO Plus+ Battery Replacement, Remove the two screws from the bottom: step 1, image 1 of 1
      • Flanking both sides of the charging port are J00 Screws. Remove these.
      • These screws go into plastic, so when re-assembling the device, be very careful not to over tighten them.
      • These two screws are identical to each other, but differ from the screws within the device, keep them separate from any screws you remove from within the device.
      Ask FixBot
    2. Pokémon™ GO Plus+ Battery Replacement, Remove Faceplace: step 2, image 1 of 2 Pokémon™ GO Plus+ Battery Replacement, Remove Faceplace: step 2, image 2 of 2
      • When looking at the front of the device, with the charging point at the bottom the device has a hinge clip and wires on the top right.
      • While opening, be extremely careful not to damage the fragile cables and connection between the main body and the faceplate.
      • With a fingernail or some kind of slim pry tool, gently lift from the bottom left corner.
      • There is adhesive that is holding the faceplate on, If you have difficulty pulling it off, use a plastic spudger by inserting it in on the bottom left then slowly hinge the device open while applying pressure to the adhesive pad to loosen it.
      Ask FixBot
    1. Pokémon™ GO Plus+ Battery Replacement, Unscrew the Battery Cover: step 3, image 1 of 1
      • Normally you'd disconnect the battery first, but with this device we cannot reach the connector until we remove the battery cover.
      Ask FixBot
    2. Pokémon™ GO Plus+ Battery Replacement, Unplug the Battery: step 4, image 1 of 1
      • This connector is the same one on the Nintendo Joy-Cons, this connector has no retention clip, and must be pried upward to remove it.
      • Step 2: Lift the battery connector UP out of the battery terminal, do not PULL backwards. Do not pry whole battery TERMINAL off the board.
      • Do not pull on the wires directly. They are fragile and will strip out of the connector with too much force, instead using the flat end of your spudger tool, reach under the wires and pry it up.
      Ask FixBot
    3. Pokémon™ GO Plus+ Battery Replacement, Remove the old Battery: step 5, image 1 of 1
      • The battery is attached to the cover with some adhesive, use your spudger to carefully and gently lever it off the cover.
      Ask FixBot
10 other people completed this guide.
Author
with
David
1,083 Reputation
5 Guides authored
10 Guide Comments
Do you need to solder the wires into the new battery, or is it just a clip system?
mitchellrochon - Reply Share
There is a connector, it's not soldered. It's the exact same part and connector is the official joycon batteries.
David - Reply Share
Goodness, I accidently threw mine in de washmachine! It didn't respond to anything, I left it to dry in rice overnight. The next morning I tried to charge it, all the lights lit up and it died with a buzzer. I thought it was gone, I ordered a new one.... Then decided to follow your guide, I bought the battery and gave it a try. It's working again! Thank you so much :D Now I have 2 plusses, I will keep the new one as a back-up, since it looks like they've been discontinued, and the few stores that still sell it have increased the price a lot. Hello inflation!
Thanks again!
Lulu - Reply Share
Where did you buy your battery from, I am in the same situation mine went for a 40minute trip in the wash machine!
-___-
PokeZed - Reply Share
Battery part #?
Jason H - Reply Share
Past 24 Hours: 35
Past 7 Days: 233
Past 30 Days: 1,236
All Time: 25,110
