Stuffed Animal Safety Eye Replacement
  1. Stuffed Animal Safety Eye Replacement, Safety Eye: step 1, image 1 of 1
    • Be sure to keep the eye that fell out and the backing or buy a new one.
    • New safety eyes are pretty inexpensive and easy to find.
    • Do not put the backing on the eye until it's in place.
  2. Stuffed Animal Safety Eye Replacement: step 2, image 1 of 1
    • The eyes on the face are located in or close to a seam that holds it in place.
    • Use your scissors to open the seam. Be very careful to cut the thread and not the fabric.
    • Make the opening of the seam so it fits the replacement eye.
  3. Stuffed Animal Safety Eye Replacement: step 3, image 1 of 1
    • Use this new hole to put the eye back in its original position.
  4. Stuffed Animal Safety Eye Replacement: step 4, image 1 of 2 Stuffed Animal Safety Eye Replacement: step 4, image 2 of 2
    • Insert the safety eye in the original position.
    • Before putting on the backing make sure it's symmetrical to the other eye.
  5. Stuffed Animal Safety Eye Replacement: step 5, image 1 of 3 Stuffed Animal Safety Eye Replacement: step 5, image 2 of 3 Stuffed Animal Safety Eye Replacement: step 5, image 3 of 3
    • When the eye is in place put the backer on the eye from the inside of the plushie.
    • Use the hole of the seam we opened to do that.
    • Press very hard until the eye and the back click together.
  6. Stuffed Animal Safety Eye Replacement: step 6, image 1 of 1
    • Sew the seam back up using a simple stitch.
    • Begin the stitches from the inside out so they are not visible, then fasten off the thread at the end of the seam.
    • The thread should be the same color as your plushie.
  7. Stuffed Animal Safety Eye Replacement: step 7, image 1 of 1
    • Take a pin and poke at the fur carefully to make it fluffy again.
    • Doing this will ensure the eye doesn't look like it's popping out.
  8. Stuffed Animal Safety Eye Replacement: step 8, image 1 of 1
    • Repeat the previous step all around the eye until it looks seamless.
    • And your done!
To reassemble your device, follow these instructions in the order suggested.
0 Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 75
All Time: 2,286
