PlayStation 4 Slim Bottom Cover Replacement
  1. PlayStation 4 Slim Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 3 PlayStation 4 Slim Bottom Cover Replacement, Bottom Cover: step 1, image 2 of 3 PlayStation 4 Slim Bottom Cover Replacement, Bottom Cover: step 1, image 3 of 3
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Remove the warranty sticker by peeling it off with any kind of spudger.
    • Removing the warranty sticker will NOT cause your warranty to be null and void.
  2. PlayStation 4 Slim Bottom Cover Replacement: step 2, image 1 of 2 PlayStation 4 Slim Bottom Cover Replacement: step 2, image 2 of 2
    • Unscrew and remove the 5.0mm screw that was behind the sticker using a T8 security Torx screwdriver with a counter-clockwise motion.
  3. PlayStation 4 Slim Bottom Cover Replacement: step 3, image 1 of 3 PlayStation 4 Slim Bottom Cover Replacement: step 3, image 2 of 3 PlayStation 4 Slim Bottom Cover Replacement: step 3, image 3 of 3
    • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
    • Pry up on the two corners that are facing you with your fingers.
    • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Remove the bottom cover by sliding it towards the back corners and lifting up.
Hernan Rodriguez
3,642 Reputation
3 Guides authored
Cal Poly, Team S19-G4, Livingston Winter 2018 Member of Cal Poly, Team S19-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G4
4 Members
35 Guides authored
Past 24 Hours: 17
Past 7 Days: 133
Past 30 Days: 759
All Time: 47,517
