Introduction
How to disassemble and change the Laser Unit.
Parts
No parts specified.
Video Overview
  1. Turn off the console and disconnect all cables.
    • Turn off the console and disconnect all cables.
  2. You must remove the warranty sticker and 4 screws. You must remove the warranty sticker and 4 screws. You must remove the warranty sticker and 4 screws.
    • You must remove the warranty sticker and 4 screws.
  3. After removing HDD bay cover, you will see another 3 screw. After removing HDD bay cover, you will see another 3 screw. After removing HDD bay cover, you will see another 3 screw.
    • After removing HDD bay cover, you will see another 3 screw.
  4. Push there to release and remove upper back bezel. Push there to release and remove upper back bezel. Push there to release and remove upper back bezel.
    • Push there to release and remove upper back bezel.
  5. The upper front bezel is harder to remove. The upper front bezel is harder to remove. The upper front bezel is harder to remove.
    • The upper front bezel is harder to remove.
  6. Remove 7 screws to release top cover. Remove 7 screws to release top cover. Remove 7 screws to release top cover.
    • Remove 7 screws to release top cover.
  7. Disconnect two flex-cables and move the Laser Unit. Remove the two screws and the small cable and then take out the Power Supply Unit. Disconnect two flex-cables and move the Laser Unit. Remove the two screws and the small cable and then take out the Power Supply Unit. Disconnect two flex-cables and move the Laser Unit. Remove the two screws and the small cable and then take out the Power Supply Unit.
    • Disconnect two flex-cables and move the Laser Unit. Remove the two screws and the small cable and then take out the Power Supply Unit.
  8. To release the laser unit disconnect this flex-cable. To release the laser unit disconnect this flex-cable. To release the laser unit disconnect this flex-cable.
    • To release the laser unit disconnect this flex-cable.
  9. One flex-cable, for rubbers and the metal bezel. One flex-cable, for rubbers and the metal bezel. One flex-cable, for rubbers and the metal bezel.
    • One flex-cable, for rubbers and the metal bezel.
  10. Disconnect this flex-cable and attach it to the new spare part. Let's start assembling. Disconnect this flex-cable and attach it to the new spare part. Let's start assembling. Disconnect this flex-cable and attach it to the new spare part. Let's start assembling.
    • Disconnect this flex-cable and attach it to the new spare part. Let's start assembling.
  11. Assembling, assembling... Assembling, assembling... Assembling, assembling...
    • Assembling, assembling...
  12. Let's test the device before fully assembling it. Let's test the device before fully assembling it.
    • Let's test the device before fully assembling it.
10 other people completed this guide.
ZFix
178,495 Reputation
315 Guides authored
Master Techs Member of Master Techs
Community
297 Members
982 Guides authored
3 Comments
Very good job, kudos!
Kevin Borras - Reply
I have found that there are to types of lasers do you sell the second one that does not have the black screws on top but are silver. I have found the one with the silver screws has a smaller laser flex cable and plug. its for the cech-43xx
jack blevinski - Reply
My only problem now is how to purchase the right Laser unit? Any specs for the right Laser unit? Thanks
Sebasttain Tuscano - Reply
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 70
All Time: 20,717
