PlayStation 3 Slim Lower Case Replacement
  1. PlayStation 3 Slim Lower Case Replacement, Top Cover: step 1, image 1 of 1
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. PlayStation 3 Slim Lower Case Replacement: step 2, image 1 of 2 PlayStation 3 Slim Lower Case Replacement: step 2, image 2 of 2
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. PlayStation 3 Slim Lower Case Replacement: step 3, image 1 of 1
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. PlayStation 3 Slim Lower Case Replacement: step 4, image 1 of 1
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  5. PlayStation 3 Slim Lower Case Replacement: step 5, image 1 of 2 PlayStation 3 Slim Lower Case Replacement: step 5, image 2 of 2
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
  6. PlayStation 3 Slim Lower Case Replacement, Power Supply: step 6, image 1 of 2 PlayStation 3 Slim Lower Case Replacement, Power Supply: step 6, image 2 of 2
    • Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
  7. PlayStation 3 Slim Lower Case Replacement: step 7, image 1 of 1
    • Pull the DC-Out cables straight up to lift their connector up and out of its socket on the power supply.
  8. PlayStation 3 Slim Lower Case Replacement: step 8, image 1 of 1
    • Remove the two 7.6 mm Phillips screws securing the power supply to the lower case.
  9. PlayStation 3 Slim Lower Case Replacement: step 9, image 1 of 1
    • Lift the power supply upward from its left edge as viewed from the front of the PS3.
  10. PlayStation 3 Slim Lower Case Replacement: step 10, image 1 of 2 PlayStation 3 Slim Lower Case Replacement: step 10, image 2 of 2
    • Continue to lift the left edge of the power supply until it lifts off the two metal posts shown in the second picture.
    • Remove the power supply from the PS3, minding any cables that may get caught.
  11. PlayStation 3 Slim Lower Case Replacement, Blu-ray Disc Drive: step 11, image 1 of 2 PlayStation 3 Slim Lower Case Replacement, Blu-ray Disc Drive: step 11, image 2 of 2
    • If present, remove the pieces of tape securing the cables to the body of the Blu-ray drive.
  12. PlayStation 3 Slim Lower Case Replacement: step 12, image 1 of 1
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the movable retaining flap, not the socket itself.
  13. PlayStation 3 Slim Lower Case Replacement: step 13, image 1 of 1
    • Pull the Blu-ray ribbon cable straight up and out of its socket.
  14. PlayStation 3 Slim Lower Case Replacement: step 14, image 1 of 1
    • Pull the Blu-ray power cable straight up to lift its connector out of the socket on the Blu-ray drive.
  15. PlayStation 3 Slim Lower Case Replacement: step 15, image 1 of 1
    • Remove the single 9.5 mm Phillips screw securing the Blu-ray drive to the lower case.
  16. PlayStation 3 Slim Lower Case Replacement: step 16, image 1 of 2 PlayStation 3 Slim Lower Case Replacement: step 16, image 2 of 2
    • Lift the Blu-ray drive slightly by its right edge to dislodge the control board from its housing.
    • Remove the Blu-ray drive from the PS3.
    • After you reinstall the Blu-ray drive, be sure the control board is firmly seated in the lower case before proceeding.
    • If replacing the Blu-ray drive with a new drive, swap the circuit board from your old drive into the new drive.
  17. PlayStation 3 Slim Lower Case Replacement, Motherboard Assembly: step 17, image 1 of 1
    • Pull the AC-In cables upward to remove the AC inlet from the lower case.
  18. PlayStation 3 Slim Lower Case Replacement: step 18, image 1 of 2 PlayStation 3 Slim Lower Case Replacement: step 18, image 2 of 2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the motherboard.
  19. PlayStation 3 Slim Lower Case Replacement: step 19, image 1 of 1
    • Pull the control board ribbon cable up and out of its socket on the motherboard.
    • Remove the control board.
  20. PlayStation 3 Slim Lower Case Replacement: step 20, image 1 of 1
    • Use the flat edge of a metal spudger to pop up the small access door on the bottom cover near the front of the PS3.
    • Remove the blue Phillips screw hidden under the access door.
  21. PlayStation 3 Slim Lower Case Replacement: step 21, image 1 of 1
    • Slide the hard drive bay cover toward the right side of the lower case, then pull it away from the front edge to remove it from the PS3.
  22. PlayStation 3 Slim Lower Case Replacement: step 22, image 1 of 1
    • Using its attached metal handle, pull the hard drive out of its bay.
  23. PlayStation 3 Slim Lower Case Replacement: step 23, image 1 of 1
    • Remove the following five screws securing the motherboard assembly to the lower case:
    • Two silver 6 mm Phillips
    • Three black 8 mm Phillips
  24. PlayStation 3 Slim Lower Case Replacement: step 24, image 1 of 1
    • Lift the motherboard assembly from its front edge and remove it from the lower case, minding the antenna cable still attached to the lower case.
    • Be careful not to bend the metal antenna bodies as you lift the motherboard assembly.
  25. PlayStation 3 Slim Lower Case Replacement, Lower Case: step 25, image 1 of 1
    • Remove the two 6.2 mm Phillips screws securing the antennas to the lower case.
  26. PlayStation 3 Slim Lower Case Replacement: step 26, image 1 of 2 PlayStation 3 Slim Lower Case Replacement: step 26, image 2 of 2
    • Lift the antennas off their plastic positioning posts and remove them from the lower case.
    • Lower case remains.
Past 24 Hours: 8
Past 7 Days: 18
Past 30 Days: 91
All Time: 19,971
