Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
Use this guide to replace the plastic lower case of your PlayStation 3 Slim.
  1. Turn the PS3 over and lay it on its backside.
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case. Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
    Its 4 screws beneath the blu-ray
    Manuel - Reply
    Daniel Tlapa - Reply
    Can we edit this to say 4 screws?
    revanantwraith - Reply
    I made the change from three to four screws, but you're able to edit the guides as well. If you want to edit something, you can click the Edit link on the right side of any guide step, or the Edit link at the top right of the page (sandwiched in-between View and History).
    Taylor Arnicar -
    Do you guys have a guide for the PS3 Slim Model 3001A. The fan is different than this model.
    emknight04 - Reply
    3001a is basically same motherboard but cheaper plastic bd drive other than that its exactly the same until you get to the new slim line
    Robert -
    Anyone know an online retailer with a competitive price for the replacement fan?
    Jared - Reply
    My PS3 had only three Torx screws. Having four in the diagram was initially confusing. Obviously they made a mid-stream change at some point (mine is several years old now).
    corygbooker - Reply
    I've accidentally removed the ribbon cable from the blu-Ray drive and can not seem to figure out how to reconnect it. Can anyone help?
    OneIfByLand - Reply
    Take the top off the drive, connect the ribbon to the motherboard then replace the drive sliding the ribbon through the slot on the bottom of the drive and reconnect to the laser.
    KcXbox Repair -
    pls help i have to tear down my ps3 slim but the 4 srews are very hard to take it out because there is a needle in the middle pls hep
    Vincent Brabandt - Reply
    If the screw has a pin in the center, that means it is a security Torx meant to prevent tampering. To remove this screw, follow the guide I have linked below...
    http://www.instructables.com/id/Removing...
    Telpack - Reply
    How do u buy the screw driver for these screws
    mistergalacta hoggy - Reply
  5. Lift the top cover from its rear edge and rotate it toward the front of the PS3. Lift the top cover off the PS3.
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
  6. Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply. Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
    • Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
  7. Pull the DC-Out cables straight up to lift their connector up and out of its socket on the power supply.
    • Pull the DC-Out cables straight up to lift their connector up and out of its socket on the power supply.
    Those two screws are tight down there what do you recommend I use?
    Megan bronner - Reply
  8. Remove the two 7.6 mm Phillips screws securing the power supply to the lower case.
    • Remove the two 7.6 mm Phillips screws securing the power supply to the lower case.
    Question: if a screw doesn't come out, what do you recommend, without potentially damaging the system, inside and out?
    kramiz2488 - Reply
    It seems these can be quite tight, but they did come loose with someextra force in my case. They did that thing where it makes cracking sounds, but nothing really breaks. They're just really tight in there. - I just wouldn't recommend taking these out too often.
    Michael Hendriks - Reply
  9. Lift the power supply upward from its left edge as viewed from the front of the PS3.
    • Lift the power supply upward from its left edge as viewed from the front of the PS3.
  10. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  11. Continue to lift the left edge of the power supply until it lifts off the two metal posts shown in the second picture. Remove the power supply from the PS3, minding any cables that may get caught.
    • Continue to lift the left edge of the power supply until it lifts off the two metal posts shown in the second picture.
    • Remove the power supply from the PS3, minding any cables that may get caught.
    It seems it kind of ends for me here. I can only lift the left side about an inch and then the right side stays down like it’s stuck to something underneath. It feels like I’m bending something. Could something have melted underneath?… It's really stuck, I can't get it to come loose. And I can't see much shining a light into it either. - Any tips?…
    Did you undo the screws?
    Phoenix Jameson -
    I had the same issue but was able to get it off. The right side (as per the above picture) has two long column like sections that actually goes into the machine. Took me a bit of wiggling and some brute force.
    Ivan Amaro - Reply
  12. If present, remove the pieces of tape securing the cables to the body of the Blu-ray drive. If present, remove the pieces of tape securing the cables to the body of the Blu-ray drive.
    • If present, remove the pieces of tape securing the cables to the body of the Blu-ray drive.
  13. Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the movable retaining flap, not the socket itself.
  14. Pull the Blu-ray ribbon cable straight up and out of its socket.
    • Pull the Blu-ray ribbon cable straight up and out of its socket.
  15. Pull the Blu-ray power cable straight up to lift its connector out of the socket on the Blu-ray drive.
    • Pull the Blu-ray power cable straight up to lift its connector out of the socket on the Blu-ray drive.
  16. Remove the single 9.5 mm Phillips screw securing the Blu-ray drive to the lower case.
    • Remove the single 9.5 mm Phillips screw securing the Blu-ray drive to the lower case.
  17. Lift the Blu-ray drive slightly by its right edge to dislodge the control board from its housing. Remove the Blu-ray drive from the PS3.
    • Lift the Blu-ray drive slightly by its right edge to dislodge the control board from its housing.
    • Remove the Blu-ray drive from the PS3.
    • After you reinstall the Blu-ray drive, be sure the control board is firmly seated in the lower case before proceeding.
    • If replacing the Blu-ray drive with a new drive, swap the circuit board from your old drive into the new drive.
    my cd drive has 3 cables, two by the fan, one right under, i believe i damaged the one on the bottom because it is very difficult to put back in hence the repair. But the photos here dont show the 3 cables, not sure if you have one for this model?
    Eduardo Cutino - Reply
    I followed the steps and I successfully removed my disc drive the guide was helpful but I had issues and the ribbon cables on my replacement disc drive were too short after a soddering attempt failed I now need to rebut a disc drive can someone direct me to a proper replacement with the correct size I need it's a ps3 slim 120G please help
    Nick - Reply
    I popped a friends apart to see if I could put in mine, which won't stay online for more than 1minute 10 seconds. Plays DVDs fine. Anyway, his had 3 cables and mine only has 1. How do I know which DVD player to order?
    ntdoc - Reply
    Completely different drive in my slim. 3 ribbon cables on the back that pull straight up out of their connectors. And one wide ribbon hidden underneath and almost impossible to get to. After disconnecting the 3 visible cables lift the back of the drive about 3/4" and use a plastic spudger to release the clip on the cable before lifting off the drive. Reinstalling is a nightmare. The cable has a black line to indicate how far to insert into the connector. Get it in there somehow then use the spudger to push the clip down. If it's not level release it and try again and again and again until you get it right. Sony must use some awfully small fingers when they build these ;-)
    jurquijo - Reply
    I had the same issue with the ribon feeding beneath the blu ray player. This video provided a much better solution. It requires dissassembling the blu ray: https://youtu.be/Upy2bTev3M0
    Rebel Seven - Reply
    My disk drive needs to be replaced. Your step by step is straight forward and are very helpful. At the end you mentioned “If replacing the Blu-ray drive with a new drive, swap the circuit board from your old drive into the new drive”.
    Which circuit board? Can your please add a picture of the circuit board you are referring to?
    Henry - Reply
    @hh168 There’s now a link in the text of that step, which will take you to a video with detailed instructions for swapping the board.
    Jeff Suovanen -
    First I replaced the drive and it would load a disc and see that it was either a game and which game or a BluRay or DVD and which, but I got error codes when trying to play them.
    The codes seemed to be tamper coding, and swapping the board seemed to be a good idea.
    It went smoothly, but now discs will not feed into the drive.
    Please help.
    Zachary Mannes - Reply
  18. Pull the AC-In cables upward to remove the AC inlet from the lower case.
    • Pull the AC-In cables upward to remove the AC inlet from the lower case.
  19. Use the flat end of a spudger to pry both antenna connectors up from their sockets on the motherboard. Use the flat end of a spudger to pry both antenna connectors up from their sockets on the motherboard.
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the motherboard.
  20. Pull the control board ribbon cable up and out of its socket on the motherboard.
    • Pull the control board ribbon cable up and out of its socket on the motherboard.
    • Remove the control board.
  21. Turn the PS3 over and lay it on its backside.
    • Use the flat edge of a metal spudger to pop up the small access door on the bottom cover near the front of the PS3.
    • Remove the blue Phillips screw hidden under the access door.
  22. Slide the hard drive bay cover toward the right side of the lower case, then pull it away from the front edge to remove it from the PS3.
    • Slide the hard drive bay cover toward the right side of the lower case, then pull it away from the front edge to remove it from the PS3.
  23. Using its attached metal handle, pull the hard drive out of its bay.
    • Using its attached metal handle, pull the hard drive out of its bay.
  24. Remove the following five screws securing the motherboard assembly to the lower case:
    • Remove the following five screws securing the motherboard assembly to the lower case:
    • Two silver 6 mm Phillips
    • Three black 8 mm Phillips
  25. Lift the motherboard assembly from its front edge and remove it from the lower case, minding the antenna cable still attached to the lower case.
    • Lift the motherboard assembly from its front edge and remove it from the lower case, minding the antenna cable still attached to the lower case.
    • Be careful not to bend the metal antenna bodies as you lift the motherboard assembly.
  26. Remove the two 6.2 mm Phillips screws securing the antennas to the lower case.
    • Remove the two 6.2 mm Phillips screws securing the antennas to the lower case.
  27. Lift the antennas off their plastic positioning posts and remove them from the lower case. Lower case remains.
    • Lift the antennas off their plastic positioning posts and remove them from the lower case.
    • Lower case remains.
9 other people completed this guide.
One Comment
On my model 3003, after reaching the end I flipped my bottom case over for dust removal etc and a silver clip fell off. I think it was located on the right (from front) side of the unit. There is another larger one attached slightly further forward. Does anyone know how the smaller one fits back in? It appears to have 2 semicircles cut out of one part which look like screw guides but I can't see anywhere they might fit and nothing I've seen here or elswhere is helping with this. Any ideas please?
Pete B - Reply
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 118
All Time: 15,608
