PlayStation 3 Memory Card Reader Replacement
  1. PlayStation 3 Memory Card Reader Replacement, Smart Plate: step 1, image 1 of 2 PlayStation 3 Memory Card Reader Replacement, Smart Plate: step 1, image 2 of 2
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 Memory Card Reader Replacement: step 2, image 1 of 1
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 Memory Card Reader Replacement: step 3, image 1 of 3 PlayStation 3 Memory Card Reader Replacement: step 3, image 2 of 3 PlayStation 3 Memory Card Reader Replacement: step 3, image 3 of 3
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 Memory Card Reader Replacement: step 4, image 1 of 1
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. PlayStation 3 Memory Card Reader Replacement, Top Cover: step 5, image 1 of 1
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. PlayStation 3 Memory Card Reader Replacement: step 6, image 1 of 1
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
  7. PlayStation 3 Memory Card Reader Replacement, Memory Card Reader: step 7, image 1 of 1
    • Remove the two 9 mm Phillips screws securing the memory card reader to the chassis.
  8. PlayStation 3 Memory Card Reader Replacement: step 8, image 1 of 2 PlayStation 3 Memory Card Reader Replacement: step 8, image 2 of 2
    • Lift the memory card reader out of the PS3 enough to access its cable.
    • Flip up the retaining flap on the memory card reader ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the memory card reader from the PS3.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 78
All Time: 18,476
