Introduction
Replace your PlayStation 2's fan.
Use the flat edge of a metal spudger to pry the eight flat screw covers out.
Remove the following eight screws securing the top cover to the bottom case:
Four 55.4 mm Philips screws
Four 18.0 mm Phillips screws
Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
Peel the warranty sticker (located next to the main power switch) straight away from the case.
Lift the top cover off the bottom case.
Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
Remove the two 6.4 mm black Phillips screws securing the optical disc drive to the bottom case.
Lift and remove the optical disc drive straight up out of the bottom case.
Remove the two 14.6 mm gold-headed Phillips securing the controller ports to the bottom case.
Gently lift the controller port board out of its recess within the bottom case.
Pull the controller port ribbon cable straight away from its socket on the controller port board.
Remove the controller port board out of the bottom case.
Remove the four 7.6 mm gold-head Phillips securing the power supply to the motherboard assembly.
Remove the small white piece of tape (highlighted in red) that holds the fan cable connected to the fan.
Pull the fan cable straight up from its socket on the motherboard.
Remove the fan and power switch assembly by pulling it out the bottom case.
