Plantronics CS50 Headset Speaker Replacement
  1. Plantronics CS50 Headset Speaker Replacement, Battery: step 1, image 1 of 3 Plantronics CS50 Headset Speaker Replacement, Battery: step 1, image 2 of 3 Plantronics CS50 Headset Speaker Replacement, Battery: step 1, image 3 of 3
    • Flip the headset face down.
    • Squeeze both sides of the battery cover.
    • While squeezing, pull the cover up slowly to remove it.
  2. Plantronics CS50 Headset Speaker Replacement: step 2, image 1 of 3 Plantronics CS50 Headset Speaker Replacement: step 2, image 2 of 3 Plantronics CS50 Headset Speaker Replacement: step 2, image 3 of 3
    • Locate and detatch the white connector that connects the wires of the battery to the wires of the headset.
  3. Plantronics CS50 Headset Speaker Replacement, Microphone: step 3, image 1 of 2 Plantronics CS50 Headset Speaker Replacement, Microphone: step 3, image 2 of 2
    • Use a hairdryer or heat gun to melt the adhesive along the crevice that joins the black and silver components.
    • Apply additional heat at the tip of the microphone.
  4. Plantronics CS50 Headset Speaker Replacement: step 4, image 1 of 2 Plantronics CS50 Headset Speaker Replacement: step 4, image 2 of 2
    • After heating the headset, use the plastic opening tool to carefully pry the black cover from the headset.
    • Be aware of the two plastic connectors inside the headset. If the black cover does not come off smoothly, apply additional heat on the connectors.
  5. Plantronics CS50 Headset Speaker Replacement: step 5, image 1 of 2 Plantronics CS50 Headset Speaker Replacement: step 5, image 2 of 2
    • Remove the microphone from the tip of the plastic.
    • You will have to lift the microphone straight up because it is held in place by a small piece of plastic.
  6. Plantronics CS50 Headset Speaker Replacement: step 6, image 1 of 2 Plantronics CS50 Headset Speaker Replacement: step 6, image 2 of 2
    • Use the heat gun to melt the adhesive connecting the headset face to the speaker casing.
    • Use the plastic opening tool to separate the speaker casing from the headset face.
    • Add extra heat to the sides to melt the adhesive between the plastic connectors.
  7. Plantronics CS50 Headset Speaker Replacement: step 7, image 1 of 2 Plantronics CS50 Headset Speaker Replacement: step 7, image 2 of 2
    • Slowly separate the motherboard from the rest of the headset.
  8. Plantronics CS50 Headset Speaker Replacement: step 8, image 1 of 1
    • Locate the microphone wires on the bottom of the motherboard.
    • Use a hairdryer or heat gun to melt the glue off of the motherboard.
  9. Plantronics CS50 Headset Speaker Replacement: step 9, image 1 of 1
    • Flip the device over.
    • Use a soldering iron to remove the solder that holds the wires to the motherboard.
    • For help soldering, click here.
    • The microphone piece should be completely detached from the motherboard.
  10. Plantronics CS50 Headset Speaker Replacement, Motherboard: step 10, image 1 of 3 Plantronics CS50 Headset Speaker Replacement, Motherboard: step 10, image 2 of 3 Plantronics CS50 Headset Speaker Replacement, Motherboard: step 10, image 3 of 3
    • Using a blow dryer or a heat gun, heat the crevice to melt the adhesive between the plastic covers.
    • Using a plastic opening tool, prop open the edges.
    • Gently pull the black speaker casing up to remove it.
  11. Plantronics CS50 Headset Speaker Replacement: step 11, image 1 of 2 Plantronics CS50 Headset Speaker Replacement: step 11, image 2 of 2
    • Use the heat gun or blow dryer to melt the glue that connects the wires to the headset's motherboard.
    • The wires should come off as they are not soldered to the motherboard.
  12. Plantronics CS50 Headset Speaker Replacement, Speaker: step 12, image 1 of 3 Plantronics CS50 Headset Speaker Replacement, Speaker: step 12, image 2 of 3 Plantronics CS50 Headset Speaker Replacement, Speaker: step 12, image 3 of 3
    • Use the heat gun to melt the adhesive that holds the bottom of the casing.
    • Use the plastic opening tool to remove the bottom of the casing.
  13. Plantronics CS50 Headset Speaker Replacement: step 13, image 1 of 3 Plantronics CS50 Headset Speaker Replacement: step 13, image 2 of 3 Plantronics CS50 Headset Speaker Replacement: step 13, image 3 of 3
    • Use the blow dryer or heat gun to melt the glue that holds the speaker.
    • Use the plastic opening tool to carefully remove the speaker from its casing.
Yuliya Levitskaya
71 Reputation
2 Guides authored
Cal Poly, Team 17-29, Amido Spring 2012 Member of Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,830
