Introduction
This guide will show you the steps to remove the drivers from the ear cups.
Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
While holding the base of the ear cup with one hand, insert your index finger from your other hand into the inside of the foam ear piece.
Remove the three screws located on the driver cover of the ear cup with the PH0 Phillips screw driver.
Almost done!
