Philips steam ironing station GC9640 solenoid valve coil replacement
  1. Philips steam ironing station GC9640 solenoid valve coil replacement, Preparation: step 1, image 1 of 1
    • Pull out the plug. If necessary, allow the device to cool down for 10 minutes. Remove the water tank. Place the iron on a suitable surface.
  2. Philips steam ironing station GC9640 solenoid valve coil replacement, Empty the steam boiler: step 2, image 1 of 1
    • Place a suitable container to catch the water.
    • Unscrew the stopper plug counterclockwise and set it aside.
  3. Philips steam ironing station GC9640 solenoid valve coil replacement, Remove the bottom of the device: step 3, image 1 of 3 Philips steam ironing station GC9640 solenoid valve coil replacement, Remove the bottom of the device: step 3, image 2 of 3 Philips steam ironing station GC9640 solenoid valve coil replacement, Remove the bottom of the device: step 3, image 3 of 3
    • Turn the device upside down.
    • Use a long screwdriver to remove 6 Torx # 15 screws
    • Remove 2 screws with a Philips # 1 screwdriver
  4. Philips steam ironing station GC9640 solenoid valve coil replacement, Open device: step 4, image 1 of 3 Philips steam ironing station GC9640 solenoid valve coil replacement, Open device: step 4, image 2 of 3 Philips steam ironing station GC9640 solenoid valve coil replacement, Open device: step 4, image 3 of 3
    • Place the unit with the bottom facing downwards. Carefully lift the upper part.
    • The keyboard in the upper part is connected by a cable harness to the motherboard. Grab the corresponding plug on both sides and remove them carefully.
    • Remove the clear hose between the water tank and the pump on the pump side. To do this, grasp under the lower edge of the hose and pull up with bending or rotating movements.
    • The upper part can now be put aside.
  5. Philips steam ironing station GC9640 solenoid valve coil replacement, Measuring the solenoid valve coils resistance: step 5, image 1 of 2 Philips steam ironing station GC9640 solenoid valve coil replacement, Measuring the solenoid valve coils resistance: step 5, image 2 of 2
    • Remove the rubber protection cap from the cable lug of the conductor.
    • Disconnect both cables from the spool. To do this, use a pointed object (eg a small screwdriver) to push the lock of the cable lug outwards, and at the same time pulling the cable lug away from the valve.
    • Use a multimeter to measure the resistance between the two contacts. It should (at least briefly) be at 30 ohms. If the resistance is infinite, the coil is defective and needs to be replaced.
    • I could not get the coil individually. The complete valve was available here: https://shop.euras.com/detailsseite_ma.p... In the comments Maxim is showing a reasonable priced source.
  6. Philips steam ironing station GC9640 solenoid valve coil replacement, Removing the solenoid coil: step 6, image 1 of 3 Philips steam ironing station GC9640 solenoid valve coil replacement, Removing the solenoid coil: step 6, image 2 of 3 Philips steam ironing station GC9640 solenoid valve coil replacement, Removing the solenoid coil: step 6, image 3 of 3
    • In order to disassemble the coil the valve must be turned approximately 30° counterclockwise. Replacing the whole valve doesn't make a lot of sense here, because the pressure hoses are partly glued together or are fixed in place with clamping rings.
    • Remove 2 Phillips screws #1 to give the hose connected to the iron more play.
    • Pull off the cable lug of the heat sensor, while pushing the pawl outwards.
    • Grab the whole valve and turn it counterclockwise until the coil is able to squeeze past the black pressure hose. You may need pliers.
    • Open the fixing nut turning a wrench counterclockwise and pull off the coil.
    • Auf Bild 4-6 kann man den Schlauch sehen, der in den Kommentaren ab 23.5.23 besprochen wird.
  7. Philips steam ironing station GC9640 solenoid valve coil replacement: step 7, image 1 of 3 Philips steam ironing station GC9640 solenoid valve coil replacement: step 7, image 2 of 3 Philips steam ironing station GC9640 solenoid valve coil replacement: step 7, image 3 of 3
    • It happens that the hose behind the solenoid valve has come loose because the plastic connector has broken.
    • The connecting piece can be replaced by a suitable aluminum tube.
    • Assembly is done by following the steps in reverse order.
21 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
John Maier
1,390 Reputation
3 Guides authored
95 Guide Comments
Vielen Dank für die tolle Einleitung! Leider sind wir von diesem Problem auch betroffen. Wollte kurz fragen ob Sie die Magnetventilspule irgendwo noch gefunden haben?
Kann man eventuell dieses nutzen? Das Modell 9640 ist nicht unter “Geeignet Für“ aufgelistet, aber ich denke nicht dass die für jedes Modell ein anderes Ventil nutzen.
https://www.fiyo.de/philips-ventil-quadr...
Kemal Zafer - Reply
Hallo,
Unter Schritt 5 habe ich einen Link angegeben, wo ich das Ventil bekommen habe. Es ist von Jiayin, mit “JYZ-5” beschriftet und hat eine Leistung von 17 Watt.
Unter Ihrem Link findet sich ein “JYZ-4P” von Jiayin mit 12 Watt Leistung.
Optisch scheinen sie baugleich, ob der Leistungsunterschied relevant ist kann ich leider nicht sagen.
Bitte rückmelden, falls es funktioniert hat. Der Preisunterschied ist deutlich.
John Maier -
Kann es trotzdem an der Spule liegen auch wenn ich dir spule schalten höre wenn ich die Taste am Bügeleisen bettätige ??
Tolga -
Hallo,
besten Dank für diese Anleitung. Mein Philips GC9622 hatte ebenfalls eine defekte Magnetventilspule. Knapp 3 Jahre nach dem Kauf. Nach dem Austausch der Spule kommt wieder Dampf. Mal sehen wie lange diese Spule hält.
Ich habe hier https://www.ersatzteileshop.de/ventil-42... das original Ersatzteil für knapp 25€ gefunden (31€ mit Versand).
Besten Dank und Viele Grüße
Maxim
Maxim - Reply
Danke für die Rückmeldung.
John
John Maier -
Past 24 Hours: 13
Past 7 Days: 232
Past 30 Days: 710
All Time: 45,059
