Philips Wake-Up HF3531/01 Disassembly
  1. Philips Wake-Up HF3531/01 Disassembly, Start: step 1, image 1 of 2 Philips Wake-Up HF3531/01 Disassembly, Start: step 1, image 2 of 2
    • There is a screw under the shiny UL sticker. Remove the sticker and screw to remove this bottom panel.
    • There are two tabs holding the panel into the clock/light, so you might have to wiggle the panel forward and out to remove it.
    There is one screw under this tab that's hold the front ring attached in fact. I guess you should have removed it too before prying this ring open
    Luuk Akkerman - Reply
    That one does not hold the ring but the cover (step 4).
    Wozu das denn -
  2. Philips Wake-Up HF3531/01 Disassembly, Prying open: step 2, image 1 of 2 Philips Wake-Up HF3531/01 Disassembly, Prying open: step 2, image 2 of 2
    • Flipping the light upside down will present a small section of the bezel that can be pried upward. It is a small plastic strip with hooks that have to be disengaged to be removed.
    Getting this section off/out without damaging it is nearly impossible. It’s hooked under the rear rim and it is held down by three clips. I ended up cutting the little bows that connect it to the back and then used pliers on one side to, well, basically break it out…
    Adjel van der Meer - Reply
    This stage was tricky but by poking a small flat-head screwdriver in alongside the tabs shown in the photo and twisting, I was able to remove it in one piece. Careful studying of of the image above shows where you need to go. Thanks for this excellent guide, I would never have figured this out without it.
    Nick Page - Reply
    Use a plastic tool or a something like a credit card to get that part out: it won’t break it and it is actually quite easy to remove (same tool used for smartphone)
    laurent reichsrath - Reply
    Wow, this would have been impossible to do without seeing the pic of the part! I managed to get it free using a tiny flat-head screwdriver to the clip (all three, one by one) and a larger one pushing up on the rim simultaneously.
    Tamar Opher - Reply
    Thanks also from my side, it would have been an impossible mission without your guide and excellent illustrations. I also succeeded to remove the plastic strip lock with a tiny flat-head screwdriver and a pair of good steel pliers. No damage.
    Cesare Liguori - Reply
    My model had a screw instead of the clips and was easy to remove. I did use a plastic pryer and think that helped.
    Mark van der Staay - Reply
  3. Philips Wake-Up HF3531/01 Disassembly, Remove the button ring: step 3, image 1 of 3 Philips Wake-Up HF3531/01 Disassembly, Remove the button ring: step 3, image 2 of 3 Philips Wake-Up HF3531/01 Disassembly, Remove the button ring: step 3, image 3 of 3
    • We can finally unscrew two more Philips head screws to remove the button ring.
    Lift one end of the ring, tilting it toward the back of the alarm clock. That will get the bows out from under the rear rim so you can start removing it..
  4. Philips Wake-Up HF3531/01 Disassembly, Front screen shield: step 4, image 1 of 1
    • Now the screws holding the front screen shield need to be removed and the shield can be pulled away to the front.
    • Screw organization note for later: these screws have pointed ends
    • Take care not to damage the internal screen.
    • Unscrew the four screws holding the inner screen assembly in place.
  5. Philips Wake-Up HF3531/01 Disassembly, Inner screen assembly: step 5, image 1 of 2 Philips Wake-Up HF3531/01 Disassembly, Inner screen assembly: step 5, image 2 of 2
    • The inner screen assembly can be pulled out slightly to reveal tabs on each side that hold the assembly in.
    • Pry the back tabs inwards to release.
    Need to push quite hard on the tabs, don’t be surprised
    totosolat - Reply
    Thank you for your comment. I was about to give up, then I read your comment and tried again pushing a little harder and it worked just fine!
    Ifelix -
    It almost seems like screws are holding it in - but man - the other commenters are right - you realllllly gotta push those tabs in to get it to release. At some point, I was like, "well, if I don't get it open, it's broken anyway, so push really really hard." Worked.
    cio - Reply
    Wooaw, that was scary but I did it. It really seems that there are additional screws to remove near the tabs, but really it's not the case. There ARE screws, but they don't need to be removed (and they face inwards anyway so they couldn't be removed).
    Félix Chénier - Reply
  6. Philips Wake-Up HF3531/01 Disassembly, Remove the screen: step 6, image 1 of 3 Philips Wake-Up HF3531/01 Disassembly, Remove the screen: step 6, image 2 of 3 Philips Wake-Up HF3531/01 Disassembly, Remove the screen: step 6, image 3 of 3
    • The screen is connected to the plastic domed back with holes. There are two screws at the back of the base of this domed panel. Remove screws to remove screen.
    • Set screen panel aside for safe keeping.
    • More to see and modify...
    Here to note that you better remove the speaker connector and release the aerial wire removing the screw that fix it on the back. I had to replace the controller of the step-down 5 V supply, so i needed full access to the bottom board. Just to note that while reassembling I swapped by mistake the speaker and the buzzer connectors, they are the same... So be careful or you have to go through the tedious opening operation once again....
    Hallo, kann man die Frontscheibe direkt auch noch abnehmen? Also damit man die innen reinigen kann?
    Christian - Reply
Finish Line
41 other people completed this guide.
Max
1,295 Reputation
1 Guide authored
13 Comments
Awesome teardown except for one little thing…
The factory sticker shows this is a 3530 which may not be different from a 3520. However, the bottom plate screw MUST be removed in order to separate the two halves. It is a little confusing saying “The bottom panel does not help gaining access to more screws. See next step.” I took that as being unnecessary, so skip.
Takkens Shoes - Reply
I was able to fix my speaker inside it i got this alarm at a thrift store for cheap turns out the one wire just needed a better conenction to get working thank you for the steps to get to it
johnstone1889 - Reply
The first photo of step 5 is a little misleading, it looks like you are unscrewing something, it made me look for the screws
Other than that this was very helpful, thank you
paulamicel - Reply
Thanks so much for this guide! The speaker in my H3510 had suddenly stopped working. I managed to take it apart with this guide. It turned out one of the wires on the speaker had come loose. We soldered it back on and that fixed it!
heleen - Reply
Thx!. Now I am able to fix the power cord which was often unplugged. So i soldered the power cable fixed to the pcb.
pibi - Reply
3520 is very similar with the first steps identical. Many thanks for this guide!
I needed to get to the little switches because they are apparently the reason for a malfunction syndrome consisting of clicking noise and disabled menu sensors (according to a post which I have now lost the track of - my apologies). I gave the switches a gentle squirt of the well known panaceum known as WD40 which they sucked in greedily, following which I exercised them a little until the click sound became clear. Reassembling was a doddle. Now I am waiting for the WD40 to (mostly) evaporate while keeping my fingers crossed (this is a good procedure and a form of exercise). Then I shall switch the light on and we shall see how successful I was. Thanks again!
Wlodek Tych - Reply
Anyone able to fix this alarm/light not powering up at all? Wondering if there’s a fuse or just developed a loose connection for the ac cable.
ark frid - Reply
Yesterday my lamp was making a clicking sound and front LED was blinking with the sound. Now LED is not displayed and it looks like it's not powering up.
Any advice?
Nilesh Patel - Reply
I have the same problem. It has been working fine for years, and then the whole lamp stopped working, lamp and LED display.. No repons what so ever. Any advice?
Alx - Reply
Quick fix: if your alarm starts behaving oddly (switched light off when alarm time reached), it could be the speaker problem. To replace steps above help reached the speaker. But there is also an option just to disconnect it, then first step is sufficient.
professor - Reply
Ha! I see I wasn't the only one experiencing "has been working fine for years, and then the whole lamp stopped working, lamp and LED display.. No re[s]pons[e] what so ever". I was able to open it thanks to this guide (whoever designed the insides of the lamp at Philips must be some sort of BDSM lover!) but I couldn't find any fuse. I left it open for a couple of weeks while I've been out of the country and I tried to power it again (still disassembled) to see if I can just throw it out. And what do you know, it just worked! I took advantage that it was disassembled and I included a very small mod - an "audio out" connector - to be used for a future Home Assistant automation project. And then I put it back together, which was a success, considering that it looks the same as before, it works perfectly, it has the additional "audio out" connector AND I also was left with 2 screws! :)) I remember one of them was holding down the small antenna wire but the other one I still can't figure where it used to go
Philips Maze - Reply
Thanks for showing how to disassemble. You helped me fix my unit :-).
Mine was acting up and maybe this can help others?:
It brightened the light when the alarm time was closed as it is supposed to, but when the alarm time was reached it turned off the light and locked up the buttons. Power had to be recycled to bring it back.
Turned out it was a bad 2200uF, 6.3v capacitor on the second PCB (the PCB connected with a flat ribbon cable to the PCB with the power connector. The PCB nearest the back cover is the one with the power connector)).
It is a capacitor located to the right on the PCB when you look at the component side. It is just next to the heat sink, so probably a bad location for a capacitor.
Desoldered the Capacitor measures "between" 27pF and "damaged component" in my component tester. A new capacitor seems to have solved the issue.
Gert Lynge - Reply
Thanks, your guide apply also for the HF3520. Mine won't power up anymore due to the defective MXT2410SX replaced thanks to another guide.
CHEERS !
Broffrey - Reply
Past 24 Hours: 11
Past 7 Days: 43
Past 30 Days: 265
All Time: 17,077
