Introduction
This bed side light is a bit tricky to open.
Purpose of this was to install an antenna jack (BNC) to attach a telescopic antenna or roof aerial.
There is a screw under the shiny UL sticker. Remove sticker and screw to remove this bottom panel. There are two tabs holding the panel into clock/light, so you might have to wiggle panel forward and out to remove it.
The bottom panel does not help gaining access to more screws. See next step
Flipping the light upside down, pry upward the small plastic strip with hooks that has to be removed.
Now the screws holding the front screen shield need to be removed and the shield can be pulled away to the front.
Unscrew the four screws holding the inner screen assembly in place.
The inner screen assembly can be pulled out slightly to reveal tabs on each side that hold the assembly in.
Pry the back tabs inwards to release.
The screen is connected to the plastic domed back with holes. There are two screws at the back of the base of this domed panel. Remove screws to remove screen.
