Introduction
Your Bodygroomer Series 5000 can not be turned on / off anymore?
Most likely it is due to the micro-button !!! This seems to be relatively inferior.
Before you start to swap the button as in my instructions, check whether the battery i.O. is.
The voltage should be at least 2.6V when charged. If this is not the case, the batteries are very likely to be defective and should be replaced.
First remove the white side parts with a thin slotted screwdriver (everything is just "clipped") First remove the white side parts with a thin slotted screwdriver (everything is just "clipped")
  • First remove the white side parts with a thin slotted screwdriver (everything is just "clipped")
Next, open the black plastic case (also like the white parts with a thin slotted screwdriver) Next, open the black plastic case (also like the white parts with a thin slotted screwdriver) Next, open the black plastic case (also like the white parts with a thin slotted screwdriver)
  • Next, open the black plastic case (also like the white parts with a thin slotted screwdriver)
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
The capsule has on the outside only 5/6 points where the upper and lower shell are connected. Next, the "waterproof capsule" must be removed and opened.
  • The capsule has on the outside only 5/6 points where the upper and lower shell are connected.
  • Next, the "waterproof capsule" must be removed and opened.
Now, when the capsule is open, you can already see the "culprit" (The small button to the right of the large IC chip) Now carefully desolder this button
  • Now, when the capsule is open, you can already see the "culprit" (The small button to the right of the large IC chip)
  • Now carefully desolder this button
Now solder in the new button The button should rest on the IC module so as not to slip / bend
  • Now solder in the new button
  • The button should rest on the IC module so as not to slip / bend
Repeat the steps in order to reassemble your device.
Special thanks to these translators:
100%
Israel is helping us fix the world! Want to contribute?
Start translating ›
bper
101 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 164
