Philips S5000 Shaver Housing Disassembly
  1. Philips S5000 Shaver Housing Disassembly, Housing Overview - Preparation: step 1, image 1 of 2 Philips S5000 Shaver Housing Disassembly, Housing Overview - Preparation: step 1, image 2 of 2
    • ATTENTION: After opening, the shaver's water resistance may be compromised!
    • Thoroughly clean the shaver before starting the work to avoid getting your workspace and the inside of the housing dirty.
    • Make sure that all parts are dry and intact.
    • Here you can see the final result with the clips marked, which should make the following steps easier to understand.
  2. Philips S5000 Shaver Housing Disassembly, Removing the Shaving Head: step 2, image 1 of 3 Philips S5000 Shaver Housing Disassembly, Removing the Shaving Head: step 2, image 2 of 3 Philips S5000 Shaver Housing Disassembly, Removing the Shaving Head: step 2, image 3 of 3
    • The shaving head is not needed for the following steps and is therefore...
    • removed from the main unit.
    • Take the shaver in your hand and pull the shaving head away from the main unit.
  3. Philips S5000 Shaver Housing Disassembly, Removing the Housing Screw: step 3, image 1 of 3 Philips S5000 Shaver Housing Disassembly, Removing the Housing Screw: step 3, image 2 of 3 Philips S5000 Shaver Housing Disassembly, Removing the Housing Screw: step 3, image 3 of 3
    • Turn the shaver over to its back side, where the only screw to be removed is located.
    • Use the T9 Torx screwdriver to loosen the screw.
  4. Philips S5000 Shaver Housing Disassembly, Loosening the Bottom of the Housing: step 4, image 1 of 3 Philips S5000 Shaver Housing Disassembly, Loosening the Bottom of the Housing: step 4, image 2 of 3 Philips S5000 Shaver Housing Disassembly, Loosening the Bottom of the Housing: step 4, image 3 of 3
    • Before you start, be aware that you must not bend the bottom part far outwards, as it is hooked in at the top of the shaver. If you don't pay attention to this, the retaining tabs will break!
    • Start at the end of the shaver in a small recess to loosen the bottom part with the spudger.
    • Work your way around both sides of the housing with the spudger until it comes loose.
  5. Philips S5000 Shaver Housing Disassembly, Removing the Lower Housing Part: step 5, image 1 of 3 Philips S5000 Shaver Housing Disassembly, Removing the Lower Housing Part: step 5, image 2 of 3 Philips S5000 Shaver Housing Disassembly, Removing the Lower Housing Part: step 5, image 3 of 3
    • To remove the bottom part, press with your finger against the upper end of the lower housing part, which is still snapped into the top part.
    • The housing snaps out towards the back and bottom.
    • Then, you can remove the lower housing part by pulling it downwards.
  6. Philips S5000 Shaver Housing Disassembly, Removing the Upper Housing: step 6, image 1 of 3 Philips S5000 Shaver Housing Disassembly, Removing the Upper Housing: step 6, image 2 of 3 Philips S5000 Shaver Housing Disassembly, Removing the Upper Housing: step 6, image 3 of 3
    • Turn the housing over again with the back facing up.
    • Use the spudger to unclip the hooks at the lower end of the housing...
    • ... then in the middle...
    • ...and finally at the top end.
    • Now you can lift the top housing part off the internal components.
To reassemble your device, follow the steps in reverse order.
Special thanks to these translators:
de en
100%
hainzy is helping us fix the world! Want to contribute?
Start translating ›
hainzy
10,466 Reputation
47 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 84
All Time: 1,008
