Introduction
Follow the procedure outlined in this guide to remove and install a speaker.
Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
Electrical Connectors
Ribbon Connectors
Slide the back panel towards top of the device and lift away from the device to detach back panel.
