Shop the Holiday Gift Guide
This guide has more recent changes. Switch to the latest unverified version.
Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement
Views: 4.8K
View statistics:
Past 24 Hours:
26
Past 7 Days:
210
Past 30 Days:
817
All Time:
4,829
Comments: 5
2 comments on steps, 3 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 hours - 2 days
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Razer uses 15v DC for charging / cable use. It has two AAA NiMH 750mAh batteries solder/welded/glued to PCB
Tools
    1. Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Remove Blade Assembley: step 1, image 1 of 1
      • Push the blade edge away from the body so it hinges at the back.
      Ask FixBot
    2. Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Remove Metal Spring Catch Plate: step 2, image 1 of 1
      • Remove 2 Philips screws that hold plate in place.
      Ask FixBot
    3. Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Remove front bezel: step 3, image 1 of 2 Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Remove front bezel: step 3, image 2 of 2
      • Pry at the sides of bottom of bezel using finger nail or pry tool.
      • Work your way up from bottom prying at sides to release the catches.
      Ask FixBot
    4. Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Remove Plastic insert below metal catch plate: step 4, image 1 of 1
      • Should just lift out using the the tab.
      Ask FixBot
    5. Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Remove Screws holding motor assembly in place.: step 5, image 1 of 1
      • Philips screw top and bottom of motor assembly
      Ask FixBot
    6. Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Remove Front Cover Screws: step 6, image 1 of 2 Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Remove Front Cover Screws: step 6, image 2 of 2
      • Remove 2x small black philips screws from front cover (below now removed bezel)
      Ask FixBot
    7. Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Remove Front Cover of Razer: step 7, image 1 of 3 Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Remove Front Cover of Razer: step 7, image 2 of 3 Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Remove Front Cover of Razer: step 7, image 3 of 3
      • Slide the front cover downwards relative to body
      • Lift Front cover off
      Ask FixBot
    8. Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Remove Electronics Assembly from case: step 8, image 1 of 3 Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Remove Electronics Assembly from case: step 8, image 2 of 3 Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Remove Electronics Assembly from case: step 8, image 3 of 3
      • This is tricky and high rise of snapping plastic case.
      • There are two black plastic clips down sides just below the ring (roughly in line with button). Release these first with flat head screwdriver and there should be a little more flex in case.
      • Then you have to life motor out of case by bending the case out of shape at the top. Do one side at a time. Don't bend case more than is necessary.
      • Then assembly should lift up to like 30 degrees so you can slide out the connector at the bottom.
      Ask FixBot
    9. Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Remove waterproof electronic housing cover: step 9, image 1 of 2 Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Remove waterproof electronic housing cover: step 9, image 2 of 2
      • First, slide the rotary ring off motor end of assembly.
      • Take note of how it comes appear as it's fiddly to reassemble
      • Then there are 6 white plastic hooks to release. These break really easily!
      Ask FixBot
    10. Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Remove Motor: step 10, image 1 of 1
      • I think motor is supposed to be removed before PCB, which I found out the hard way.
      • Slide off the plastic housing around motor.
      • If you then pull shaft firmly it should just pull out (pass waterproofing seals)
      Ask FixBot
    11. Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Remove PCB: step 11, image 1 of 3 Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Remove PCB: step 11, image 2 of 3 Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Remove PCB: step 11, image 3 of 3
      • PCB and battery assembly are just held into plastic housing by spring loaded metal contacts for DC in connector (and motor before it was removed).
      • With some gentle prying it should just lift out...
      Ask FixBot
    12. Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Removing Battery from PCB: step 12, image 1 of 3 Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Removing Battery from PCB: step 12, image 2 of 3 Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Removing Battery from PCB: step 12, image 3 of 3
      • This is what top of PCB looks like. The 2nd photo is after I've swopped batteries. Note that PCB says 'Jaguar-NiMH'.
      • To be super helpful batteries are spot welded together, and to pins, which are then soldered to PCB. Plus the batteries are glued into the plastic PCB support.
      • Note: The PCB is still powered until batteries are removed, so be carefully not to short anything!
      • After various attempts I conclude best approach as to use a small paint brush to apply white spirit repeatedly to gap between the batteries, and between batteries and plastic at sides of PCB assembly. I then left it 24h to do it's work.
      • Then force a small flathead screwdriver (with PCB on a flat cushioned surface so a not to bend it) between battery terminals, and the flat metal pins that are solder into PCB (button end of batteries). You will bend plastic and pins, but you should be able to break the spot welded joints.
      • Note: You can leave the plate at other end holding batteries together in situ.
      • Then using a thin knife blade try and losen the glue between batteries and plastic.
      • Finally using a pry tool in the corners, starting at DC-In connector end of batteries, try and life them out of plastic slots. If you struggling, use more white spirit, and check you've fully broken spot welds.
      Ask FixBot
    13. Philips Beardtrimmer (Electric Razer) 5000 series (BT5200) Battery Replacement, Don't get distracted...: step 13, image 1 of 1
      • There is two screws and a small bit of plastic on the bottom of motor housing. You can remove it, but it achieves nothing.
      Ask FixBot
      • You can check the motor works, pcb and new battery work together before re-assembling. Just should spring connectors together on the bench and press the button on pcb. LEDs will come one, and motor will spin (and try and walk across bench)
      Ask FixBot
There is need to leave white spirit to disolve glue, it's probably only 2-3h work
It's really fiddly to get the rotary ring assembly back together.... but possible.
I didn't bother putting glue to hold batteries to PCB assembly, as housing is snug, and it feel like deterrent....
5 other people completed this guide.
Author
with
P Badrick
890 Reputation
4 Guides authored
3 Guide Comments
I just managed to successfully change the batteries in my trimmer thanks to this wonderful guide, thanks so much for posting it!
Tobias Carpenter - Reply Share
Thank you for the guide, I could also fix my trimmer :)
Though, I did not find a good solution to substitute the spot welding. Seems like that metal piece slipped again, and now mine is not working anymore. So I have to open it on another day..
Felix J - Reply Share
Thank you very much for this guide.
Seems like I can use my trimmer without the charging cable again :)
Benni - Reply Share
Past 24 Hours: 26
Past 7 Days: 210
Past 30 Days: 817
All Time: 4,829
