Petlibro Granary WIFI Feeder Technique
  1. Petlibro Granary WIFI Feeder Technique, Take it apart: step 1, image 1 of 1
    • Take machine apart and remove all visible screws. You need a skinny, long screwdriver for this.
    Ask FixBot
  2. Petlibro Granary WIFI Feeder Technique, Identify important wires: step 2, image 1 of 1
    • The infrared sensor has an emitting diode and a receiver. note the receiver on the right side. These are the wires we will clip and attach to each other.
    Ask FixBot
  3. Petlibro Granary WIFI Feeder Technique, Clip and splice: step 3, image 1 of 1
    • Clip both wires leading to the receiver (green/red) and splice these together. This will bypass the infrared sensor.
    Ask FixBot
  4. Petlibro Granary WIFI Feeder Technique, Validate bypass: step 4, image 1 of 1
    • Validate that warning light is gone and device is functional before screwing everything together. We are done.
    Ask FixBot
4 other people completed this guide.
Matt
220 Reputation
1 Guide authored
2 Guide Comments
Very helpful fix(the notation about screws’ location was key); worked perfectly. Expensive feeder is no longer a brick!
Talby - Reply Share
solved my problem, thank you!
Thuan Pham - Reply Share
Past 24 Hours: 4
Past 7 Days: 34
Past 30 Days: 131
All Time: 4,359
