Dexter 900W Corded Hammer Drill - 900ID2.5 Output Shaft Replacement
  1. Dexter 900W Corded Hammer Drill - 900ID2.5 Output Shaft Replacement, Unplug: step 1, image 1 of 1
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter 900W Corded Hammer Drill - 900ID2.5 Output Shaft Replacement: step 2, image 1 of 2 Dexter 900W Corded Hammer Drill - 900ID2.5 Output Shaft Replacement: step 2, image 2 of 2
    • Remove the handle from the machine.
  3. Dexter 900W Corded Hammer Drill - 900ID2.5 Output Shaft Replacement: step 3, image 1 of 2 Dexter 900W Corded Hammer Drill - 900ID2.5 Output Shaft Replacement: step 3, image 2 of 2
    • Open the chuck to the maximum to gain access to the inner screw.
  4. Dexter 900W Corded Hammer Drill - 900ID2.5 Output Shaft Replacement: step 4, image 1 of 2 Dexter 900W Corded Hammer Drill - 900ID2.5 Output Shaft Replacement: step 4, image 2 of 2
    • Lock the chuck using a 15 spanner (thickness 3), then unscrew to the right with a pz3 screwdriver.
    • Using a pair of pliers, unscrew the chuck.
  5. Dexter 900W Corded Hammer Drill - 900ID2.5 Output Shaft Replacement: step 6, image 1 of 2 Dexter 900W Corded Hammer Drill - 900ID2.5 Output Shaft Replacement: step 6, image 2 of 2
    • Using a screwdriver or screwdriver, unscrew and open the device.
  6. Dexter 900W Corded Hammer Drill - 900ID2.5 Output Shaft Replacement: step 7, image 1 of 1
    • Unscrew the four screws.
    • Using a screwdriver, lift the spring of the two brushes.
    • Remove the output shaft.
    • Before replacing the new part, be sure to re-grease.
    • Reposition the brush springs.
  7. Dexter 900W Corded Hammer Drill - 900ID2.5 Output Shaft Replacement: step 11, image 1 of 1
    • Then retighten the four screws.
  8. Dexter 900W Corded Hammer Drill - 900ID2.5 Output Shaft Replacement: step 12, image 1 of 2 Dexter 900W Corded Hammer Drill - 900ID2.5 Output Shaft Replacement: step 12, image 2 of 2
    • Before closing, check that no cable is blocked and that each part is in its place.
    • Tighten the screws to close the device.
  9. Dexter 900W Corded Hammer Drill - 900ID2.5 Output Shaft Replacement: step 13, image 1 of 1
    • Replace the chuck.
  10. Dexter 900W Corded Hammer Drill - 900ID2.5 Output Shaft Replacement: step 14, image 1 of 2 Dexter 900W Corded Hammer Drill - 900ID2.5 Output Shaft Replacement: step 14, image 2 of 2
    • Screw the chuck back on by hand.
    • Then using a screwdriver replace the screw, and screw to the left.
  11. Dexter 900W Corded Hammer Drill - 900ID2.5 Output Shaft Replacement: step 15, image 1 of 2 Dexter 900W Corded Hammer Drill - 900ID2.5 Output Shaft Replacement: step 15, image 2 of 2
    • Finally replace the handle.
in order to reassemble preform the steps in reverse order.
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
16,581 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
36 Members
239 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 924
