Pebble Time Screen Replacement
  1. Pebble Time Screen Replacement, Screen Cover: step 1, image 1 of 1
    • Lay the watch flat on your workstation.
  2. Pebble Time Screen Replacement: step 2, image 1 of 2 Pebble Time Screen Replacement: step 2, image 2 of 2
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Screen Replacement: step 3, image 1 of 1
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Screen Replacement: step 4, image 1 of 1
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Screen Replacement, Screen: step 5, image 1 of 1
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Screen Replacement: step 6, image 1 of 1
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Screen Replacement: step 7, image 1 of 3 Pebble Time Screen Replacement: step 7, image 2 of 3 Pebble Time Screen Replacement: step 7, image 3 of 3
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
Saud Al-Malki
110 Reputation
1 Guide authored
USF Tampa, Team 1-3, Sullivan Spring 2017 Member of USF Tampa, Team 1-3, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G3
4 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 3,173
