Introduction
Replacement guide for the circuit board of the Pebble Time.
Use the metal spudger to carefully pull apart the screen cover from the case.
Replace the metal spudger with a plastic opening tool to hold the cover open.
Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
Disconnect the screen from the circuit board.
Locate the three screws on the circuit board.
Remove using the J000 Philips head screwdriver.
Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
Move apart the connector to expose the fourth screw.
Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
Remove the circuit board from the case.
