Patch your Patagonia Nano Puff ® Jacket with Repair Tape
  1. Patch your Patagonia Nano Puff ® Jacket with Repair Tape, Patch your Patagonia Nano Puff ® Jacket with Repair Tape: step 1, image 1 of 1
    • Inspect the damage on your jacket. Clip any dangling threads or fabric using small scissors.
  2. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: step 2, image 1 of 3 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: step 2, image 2 of 3 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: step 2, image 3 of 3
    • Grab your repair tape.
    • Flip the repair tape to the back side.
    • Using a permanent marker, draw an oval slightly larger than the hole.
    • If you have a wide hole, you can use a rectangle, but be sure to round the edges. Rounding the edges prevents the corners from getting caught and peeling up.
  3. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: step 3, image 1 of 2 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: step 3, image 2 of 2
    • Cut out your shape using scissors.
  4. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: step 4, image 1 of 3 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: step 4, image 2 of 3 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: step 4, image 3 of 3
    • Using your fingernail, or a pin, peel the backing off the tenacious tape, so that you only have the clear sticky layer.
    • Be sure not to touch the sticky side of the tape as this will gum up the tape and it won’t stick well.
  5. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: step 5, image 1 of 2 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: step 5, image 2 of 2
    • Lay the tape over the hole and press the tape down with your finger.
  6. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: step 6, image 1 of 2 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: step 6, image 2 of 2
    • Use a fingernail or spudger to work out all of the air bubbles under the tape. Continue rubbing the tape until it is well-adhered.
Finish Line
9 other people completed this guide.
Brittany McCrigler
89,012 Reputation
131 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,767 Guides authored
2 Comments
I followed this tutorial and used Tenacious tape by Gear Aid because it claims to not leave a residue behind if removed. That was a bad idea. I am now ready to upgrade this patch to a sewn one and removing the tape is absolutely leaving behind a residue. Really annoyed right now.
Ling Wang - Reply
This is really helpful, thanks.
James
James Riley - Reply
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 165
All Time: 45,293
