Introduction
This guide will explain how to easily replace a dead or dying battery on the Parrot Hydrofoil Orak. A plastic opening tool will be useful, as part of the removal may hurt if you use your fingernail.
Parts
No parts specified.
  1. Orient the device so that the front of the boat chasis is facing to your right.
    • Orient the device so that the front of the boat chasis is facing to your right.
  2. Use your pointer finger on one tab, your middle finger on the other, and your thumb on the bottom to pry the tabs away and lift the drone out of the holder. Use your pointer finger on one tab, your middle finger on the other, and your thumb on the bottom to pry the tabs away and lift the drone out of the holder. Use your pointer finger on one tab, your middle finger on the other, and your thumb on the bottom to pry the tabs away and lift the drone out of the holder.
    • Use your pointer finger on one tab, your middle finger on the other, and your thumb on the bottom to pry the tabs away and lift the drone out of the holder.
  3. MacBook Battery Fix Kits
    Starting at $69.99
    Buy Now
    Starting at $69.99
    Buy Now
  4. Insert your plastic opening tool in between the tab with the arrow on it and the battery below it. Pry the tool upwards to disengage the battery.
    • Insert your plastic opening tool in between the tab with the arrow on it and the battery below it.
    • Pry the tool upwards to disengage the battery.
    • You can disengage the battery with your finger rather than an opening tool, although it takes quite a bit of force and you may need strong nails.
  5. Pull the battery fully out using your fingers.
    • Pull the battery fully out using your fingers.
Matt Sterling
171 Reputation
1 Guide authored
Cal Poly, Team 20-2, Livingston Fall 2016 Member of Cal Poly, Team 20-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G2
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 274
