Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement
Video Overview
  1. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 2, image 1 of 2 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 2, image 2 of 2
    • Disconnect the battery by pulling the two red wires apart.
    • Remove the battery by releasing the battery retaining straps.
  2. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 3, image 1 of 2 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 3, image 2 of 2
    • Turn the drone upside down.
    • The cover is held on by plastic tape. Peel off the tape and use a spudger to remove the back cover.
  3. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 4, image 1 of 3 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 4, image 2 of 3 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 4, image 3 of 3
    • Using a spudger, separate the connector for the downward camera.
    • Remove the camera from the body by pulling it off the foam body.
  4. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 5, image 1 of 2 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 5, image 2 of 2
    • Use a spudger to release the black retaining clip. Then disconnect the connector to the sensors.
    • Use tweezers to carefully remove the ribbon from the connector.
  5. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 6, image 1 of 1
    • Remove the four 8mm torx screws with a T6 bit.
    • Remove the four 8mm philips head screws with a PH00 bit.
  6. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 7, image 1 of 2 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 7, image 2 of 2
    • Carefully pull the secondary board from the mainboard.
  7. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 8, image 1 of 3 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 8, image 2 of 3 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 8, image 3 of 3
    • Turn the drone right side up
    • Remove the USB connector from the battery retaining straps.
  8. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 9, image 1 of 1
    • Release the rubber clip holding the USB and battery power cable to the body.
  9. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 10, image 1 of 2 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 10, image 2 of 2
    • Avoid using sharp tools near the battery.
    • Push the USB and power cable through the battery panel.
  10. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 11, image 1 of 2 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 11, image 2 of 2
    • Turn the drone upside down again.
    • Use a spudger to release the connector and carefully remove the ribbon.
  11. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 12, image 1 of 2 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 12, image 2 of 2
    • Lift the mainboard up so that you can access the back.
    • Disconnect the first connector with the white wires using a nylon spudger.
    • Disconnect the second connector with the red and black wires using a spudger.
  12. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: step 13, image 1 of 1
    • The mainboard is now fully detached and can be removed.
David Hoyt
4,023 Reputation
43 Guides authored
Cal Poly, Team 25-89, Amido Spring 2010 Member of Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Members
63 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 17
All Time: 6,711
