Panasonic SC-PM31 Cassette Player Replacement
  1. Panasonic SC-PM31 Cassette Player Replacement, Removing the side and back screws: step 1, image 1 of 3 Panasonic SC-PM31 Cassette Player Replacement, Removing the side and back screws: step 1, image 2 of 3 Panasonic SC-PM31 Cassette Player Replacement, Removing the side and back screws: step 1, image 3 of 3
    • Remove the five 9 mm #2 Phillips screws from the side panel nearest the power button.
    • Repeat the process for the opposite panel.
    • Remove the two 15 mm #2 Phillips screws from the back of the top panel.
    • Remove the middle 10mm #2 Phillips screw from the back of the top panel.
  2. Panasonic SC-PM31 Cassette Player Replacement, Removing the panels: step 2, image 1 of 2 Panasonic SC-PM31 Cassette Player Replacement, Removing the panels: step 2, image 2 of 2
    • If you do not have a plastic opening tool, you can open the system using your finger. However, if you choose to use your hands, make sure to wear gloves. The panel is very sharp.
    • Swing the back half of the panel slightly away from the unit. Then, starting at the top back corner, slide plastic opening tool through the created gap from back to front. The panel should pop off. Repeat the process on the opposite panel.
  3. Panasonic SC-PM31 Cassette Player Replacement, Removing the white ribbon wire: step 3, image 1 of 1
    • Looking in through the side nearest the power button, use your fingers to pull the white ribbon connection toward you, away from the rear circuit board.
    • The process will require the use of moderate force and can be eased by wiggling the ribbon during removal.
  4. Panasonic SC-PM31 Cassette Player Replacement, Removing the top panel: step 4, image 1 of 2 Panasonic SC-PM31 Cassette Player Replacement, Removing the top panel: step 4, image 2 of 2
    • Remove the top panel. You will need to slightly bend the plastic tab outwards, to undo the clasp that is attached to the top.
    • When reassembling the device, reattach the white ribbon wire (Step 3) before replacing the top panel.
  5. Panasonic SC-PM31 Cassette Player Replacement, Removing the circuit board: step 5, image 1 of 1
    • Turn the top panel upside down.
    • Remove the four Phillips #2 dome-headed screws with length 9.5mm holding the cassette assembly to the plastic exterior.
  6. Panasonic SC-PM31 Cassette Player Replacement, Removing the smaller circuit board: step 6, image 1 of 2 Panasonic SC-PM31 Cassette Player Replacement, Removing the smaller circuit board: step 6, image 2 of 2
    • Remove the Phillips #2 screw with length 9.5mm from the small circuit board.
    • Lift the small circuit board from the plastic.
  7. Panasonic SC-PM31 Cassette Player Replacement, Removing the cassette player: step 7, image 1 of 2 Panasonic SC-PM31 Cassette Player Replacement, Removing the cassette player: step 7, image 2 of 2
    • Lift the device up. With your right hand index finger, press the latch towards you to manually move the rear latch to open the cassette door.
    • The cassette door will open underneath.
  8. Panasonic SC-PM31 Cassette Player Replacement, Removing the cassette player: step 8, image 1 of 1
    • Carefully lift the cassette player out of the plastic casing.
Jessica Chao
626 Reputation
5 Guides authored
Cal Poly, Team 13-7, Forte Fall 2014 Member of Cal Poly, Team 13-7, Forte Fall 2014
CPSU-FORTE-F14S13G7
5 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 961
