Introduction
Step by step guide to replacing your digital camera door.
Remove the battery and memory card from the unit
Remove 6 (0.3mm) screws from the sides of the unit
Remove 5 (0.3mm) screws from the bottom of the unit
Complete the following review guide: LCD removal
Remove the front cover
Use tweezers or a thin object to push door pin thru enough to grab from the other side.
Pull out door pin using needle nose pliers or other tool.
Notice spring positioning. This will help you re-install your replacement door
